I am having a problem with my USB zigbee dongle , TI cc2531 that I bought from ebay and home assistant
I set up zigbee2mqtt addon using instructions. The cc2531 was already flashed.
the failure used to happen sometime after my Raspberry Pi 4-based HA was turned on. initially the green(led2) one would be blinking and the red led (led1) would be fully lit, after some time I noticed the led’s would be turned off. and I would see sth like the following in HA logs
2021-02-16 12:29:44 ERROR (MainThread) [zigpy.application] Couldn't start application
2021-02-16 12:29:44 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start Legacy TI_CC = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 157, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.8/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.8/site-packages/zigpy_cc/zigbee/application.py", line 95, in startup
await self._api.request(Subsystem.SYS, "ping", {"capabilities": 1})
File "/usr/local/lib/python3.8/site-packages/zigpy_cc/api.py", line 117, in request
return await self.request_raw(obj, waiter_id, expected_status)
File "/usr/local/lib/python3.8/site-packages/zigpy_cc/api.py", line 121, in request_raw
return await self._request_raw(obj, waiter_id, expected_status)
File "/usr/local/lib/python3.8/site-packages/zigpy_cc/api.py", line 141, in _request_raw
result = await waiter.wait()
File "/usr/local/lib/python3.8/site-packages/zigpy_cc/api.py", line 47, in wait
return await asyncio.wait_for(self.future, self.timeout / 1000)
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 501, in wait_for
raise exceptions.TimeoutError()
asyncio.exceptions.TimeoutError
2021-02-16 12:29:44 WARNING (MainThread) [homeassistant.config_entries] Config entry 'TI CC2531 USB CDC, s/n: __0X00124B0008C52703 - Texas Instruments' for zha integration not ready yet. Retrying in 80 seconds
also
[596456.451398] cdc_acm 1-1.2:1.0: failed to set dtr/rts
on the host kernel logs.
Right now, it has a solid red led, probably because I reset it.
Any suggestions?
I could upgrade to a more dependable zigbee usb dongle if that would help
