hey folks,
i have this one: TS0601
and its mqtt output is:
but when i search for entities the illuminance is missing:
What might be the problem? Am i missing something?
hey folks,
I have 3 of this senors. The problem with it is battery on the first place. Buy yourself a decent battery.
Next problem is that those are pir sensors working on battery. Pir sensors should have mains power.
If you pair them and after few hours you wanna change some settings you will see that it doesn’t work.
They are hard to setup and setup should be done as soon as they are paired with coordinator.
On the other hand they can work pretty reliable when you set up them.
I don’t recommend people to buy them because there are a lot of senors with lux and motion detection that works much better than this.
Yes okay, thats maybe true but a different problem. Thanks for the advice!
Check for hidden or disabled entities. It might be there. I don’t use MQTT so I can’t offer any more specific advice on it.
yes, thank you.
It was “deaktivated by integration”. Why ever… cant figure out a reason…
Please mark my post as answer. Thanks!
