Hello guys, I am not sure that this is the right plase for my question, but I need help. I am running the lates version of HA (2021.10.6) with zigbee2mqtt (1.18.1-1) on rpi4. For the zigbee plugin I am uing Texas_Instruments_TI_CC2531_USB. I am trying to connect Xiaomi DLKZMK11LM (Xiaomi DLKZMK11LM control via MQTT | zigbee2mqtt.io) to zigbee2mqtt and even though it is supported Zigbee plugin says that it is not supported. Do any of you guys has experience with that relay?
That version is way to old. We’re on 1.21.2 now. You miss all the devices that have been added since.
Yes, but in my supervisor section I don’t have update option regarding zigbee2mqtt. I am not using the edge version. Is there a way to manually update the plugin?
You are using the deprecated daniel welch add-on. Use the official Zigbee2MQTT add-on.
Thank you for the quick answer. I will give it a try.
