I am having some problems with the Aeotec ZW100 MultiSensor 6
It’s added normal to my z-wave network (Z-Stick Gen5) together with a nano dimmer and a wallmote that are all working fine.
The MultiSensor seams to be working but i can’t get the motion sensing to work, i have tried basic set and binary sensor report.
Either way the problem is all the same, in home assistant the burglar sensor constantly changes between 0 and 8 (binary sensor on and off) several times per minute even when no one is in the room.
I have tried to change
Other values like temperature and light seams normal to me.
am i missing something here, does it have to be added securely? or is there som other setting i need to change
The burglar sensor detects both tampering and motion. I have used mine without changing to binary for almost 2 years now. Value 3 is for tampering and 8 for motion.
But the last 3-4 days after a restart of hass.io I have trouble making one of them to work. The one is reporting fine but the other one is almost like is dead. I have already remove the node and added again but it didn’t help. Except having problem with the one of the multisensors, it seems that z-wave is a little bit unstable for me the last month. It could be the hass.io but it could be also that the sensor that is not working properly that is causing problems in my z-wave network. Any ideas?
