Hi Guys,
I am currently working on a project where I use ESPHome with an ESP32 to dynamically change the background of my LVGL display based on a select
module. However, I’m facing an issue: while the input is recognized and the ESP32 attempts to switch the background image, the display briefly flickers but then goes blank.
My Setup:
I have defined several background images in the image
section of my YAML configuration, all resized to 850x550 and using the RGB565 format.
Here’s a snippet of my image
setup:
image:
- file: "Media/doorbell/bg_fullsize.jpg"
type: RGB565
resize: 850x550
- file: "Media/doorbell/bg_light.jpg"
resize: 850x550
type: RGB565
- file: "Media/doorbell/mountains.jpg"
resize: 850x550
type: RGB565
- file: "Media/doorbell/fluids.jpg"
resize: 850x550
type: RGB565
- file: "Media/doorbell/layers.jpg"
resize: 850x550
type: RGB565
- file: "Media/doorbell/mountainsae.jpg"
resize: 850x550
type: RGB565
I also configured a select
module with options corresponding to these images. The logic for updating the background is implemented in the on_value
section, using the lvgl.update
action.
select:
optimistic: True
initial_option: Darkmode-Standard
options:
- Darkmode-Standard
- Lightmode-Standard
- Mountains
- Darkmode-Fluids
- Layers
- Mountains-Aesthetics
on_value:
then:
- logger.log:
format: "Background: %s (index %d)"
args: ["x.c_str()", "i"]
- if:
condition:
lambda: |-
return (id(select_bg).active_index() == 0);
then:
- logger.log: "Darkmode-Standard"
- lvgl.update:
disp_bg_image: darkmode
- if:
condition:
lambda: |-
return (id(select_bg).active_index() == 1);
then:
- logger.log: "Lightmode-Standard"
- lvgl.update:
disp_bg_image: lightmode
- if:
condition:
lambda: |-
return (id(select_bg).active_index() == 2);
then:
- logger.log: "Mountains"
- lvgl.update:
disp_bg_image: mountains
- if:
condition:
lambda: |-
return (id(select_bg).active_index() == 3);
then:
- logger.log: "Darkmode-Fluids"
- lvgl.update:
disp_bg_image: fluids
- if:
condition:
lambda: |-
return (id(select_bg).active_index() == 4);
then:
- logger.log: "Layers"
- lvgl.update:
disp_bg_image: layers
- if:
condition:
lambda: |-
return (id(select_bg).active_index() == 5);
then:
- logger.log: "Montains-Aesthetics"
- lvgl.update:
disp_bg_image: mountainsae
The Problem:
When I select a new background using the select
module, the ESP32 logs the selection correctly, and the lvgl.update
command is executed. However, the display only flickers briefly before going blank. No image is shown on the screen.
What I’ve Tried:
- Ensured all images are in RGB565 format and resized appropriately.
- Verified that the image IDs are correctly referenced in the
lvgl.update
command. - Checked the ESPHome logs, which confirm that the
select
input is received and processed.
Questions:
- Has anyone successfully implemented dynamic background switching with LVGL in ESPHome?
- Could the issue be related to buffer size, image format, or display compatibility?
- Are there additional debugging steps or configurations I should consider?
image:
type: RGB565
resize: 850x550
resize: 850x550
type: RGB565
resize: 850x550
type: RGB565
resize: 850x550
type: RGB565
resize: 850x550
type: RGB565
resize: 850x550
type: RGB565
select:
optimistic: True
options:
- Darkmode-Standard
- Mountains
- Darkmode-Fluids
- Layers
on_value:
then:
- logger.log:
- if:
condition:
lambda: |-
then:
- lvgl.update:
- if:
condition:
lambda: |-
then:
- lvgl.update:
- if:
condition:
lambda: |-
then:
- lvgl.update:
- if:
condition:
lambda: |-
then:
- lvgl.update:
- if:
condition:
lambda: |-
then:
- lvgl.update:
- if:
condition:
lambda: |-
then:
- lvgl.update:
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_orange
red: 100%
green: 50%
blue: 0%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_purple
red: 45%
green: 0%
blue: 75%
- id: my_teal
red: 0%
green: 100%
blue: 100%
- id: my_gray
red: 70%
green: 70%
blue: 70%
- id: my_blue
red: 0%
green: 0%
blue: 70%
- id: my_white
red: 100%
green: 100%
blue: 100%
- id: my_black
red: 0%
green: 0%
blue: 0%
- id: my_blackhex
hex: 191919
lvgl:
buffer_size: 100%
log_level: INFO
displays:
- my_display
theme:
button:
bg_color: my_black
bg_opa: 20%
border_width: 5
border_color: my_black
radius: 10
shadow_color: my_black
shadow_opa: 100%
shadow_width: 10
text_color: my_white
text_font: montserrat_36
pages:
- id: home
widgets:
- button:
align: CENTER
y: -120
width: 750
height: 200
checkable: false
widgets:
- label:
align: CENTER
text: "K. Klaus"
on_click:
- lvgl.page.show:
animation: FADE_OUT
time: 1000ms
- delay: 30s
- lvgl.page.show:
animation: FADE_OUT
time: 1000ms
I’d really appreciate any insights or guidance on how to resolve this issue!
Thank you!
