Problems adding Sonoff buttons to HA
Hi, I have just bought two Sonoff SNZB-01s and added one to ZHA as a device but the second one just will not pair as the first one did.
I can view the logs and see it talking to it but it just doesn’t get added as a device.
Anyone got any suggestions?
Here’s the log
Device 0x082f (00:12:4b:00:29:11:4c:de) left the network
0x3288: Device seen - marking the device available and resetting counter
0x3288: Update device availability - device available: True - new availability: True - changed: False
Device 0x082f (00:12:4b:00:29:11:4c:de) joined the network
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x082F), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.Broadcast: 15>, address=<BroadcastAddress.ALL_ROUTERS_AND_COORDINATOR: 65532>), dst_ep=0, source_route=None, extended_timeout=False, tsn=0, profile_id=0, cluster_id=19, data=Serialized[b’\x00/\x08\xdeL\x11)\x00K\x12\x00\x80’], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=160, rssi=-60)
[0x082f:zdo] ZDO request ZDOCmd.Device_annce: [0x082F, 00:12:4b:00:29:11:4c:de, 128]
Sorted it, restarted HA and it worked.
