After installing latest updates I get an error notification saying “Invalid config” and then i’m not able to use Automations and Default Config
Can anyone pls help with what to do - do i need to go back to the previous snapshot or is there a way to make it work? I’m running HA on a Mac on ViruelBox VM
The following integrations and platforms could not be set up:
Here is the text from the log -
Setup failed for default_config: Could not set up all dependencies.
16 June 2021, 17:04:04 – (ERROR) setup.py
Unable to set up dependencies of default_config. Setup failed for dependencies: automation
Error during setup of component automation
16 June 2021, 17:04:02 – (ERROR) components/device_automation/init.py
Ended unfinished session (id=12 from 2021-06-16 14:58:13.044085)
16 June 2021, 17:03:50 – (WARNING) Recorder
