After upgrade to 0.88.2 bunch of components not available.
RTL_433 to MQTT component
Broadlink entities
parts of Tasmota devices (temperature sensor is missing, and switch is present)
weather sensor (sensor.pws_weather… yr.sensor)
Qnap sensor
here are pictures:
Read the 0.88 Release Notes. Some invalid MQTT elements that were ignored now generate errors. Use the error logs and online documentation to find & fix the invalid elements.
I am searching, but haven’t find a solution
It seems that Broadlink component doesn’t work at all.
I remember in some instance of upgrade, broadlink component has to be added as custom component into config dir.
So, how to use Broadlink component with 0.89 version?
I believe that someone else will also have problems like this.
