Hya, by trying to upgrade HA, i get the following error, under ubuntu 18.04 LTS.
homeassistant@wolke:~$ python3.9 -m pip install --upgrade homeassistant -
ERROR: Exception:
File "/usr/lib/python3/dist-packages/pip/_internal/cli/base_command.py", line 165, in exc_logging_wrapper
status = run_func(*args)
File "/usr/lib/python3/dist-packages/pip/_internal/cli/req_command.py", line 205, in wrapper
return func(self, options, args)
File "/usr/lib/python3/dist-packages/pip/_internal/commands/install.py", line 255, in run
options.use_user_site = decide_user_install(
File "/usr/lib/python3/dist-packages/pip/_internal/commands/install.py", line 667, in decide_user_install
if site_packages_writable(root=root_path, isolated=isolated_mode):
File "/usr/lib/python3/dist-packages/pip/_internal/commands/install.py", line 613, in site_packages_writable
for d in set(get_lib_location_guesses(root=root, isolated=isolated))
File "/usr/lib/python3/dist-packages/pip/_internal/commands/install.py", line 599, in get_lib_location_guesses
scheme = get_scheme(
File "/usr/lib/python3/dist-packages/pip/_internal/locations/__init__.py", line 244, in get_scheme
old = _distutils.get_scheme(
File "/usr/lib/python3/dist-packages/pip/_internal/locations/_distutils.py", line 130, in get_scheme
scheme = distutils_scheme(dist_name, user, home, root, isolated, prefix)
File "/usr/lib/python3/dist-packages/pip/_internal/locations/_distutils.py", line 69, in distutils_scheme
i.finalize_options()
File "/usr/lib/python3.9/distutils/command/install.py", line 306, in finalize_options
(prefix, exec_prefix) = get_config_vars('prefix', 'exec_prefix')
File "/usr/lib/python3.9/distutils/sysconfig.py", line 512, in get_config_vars
func()
File "/usr/lib/python3.9/distutils/sysconfig.py", line 472, in _init_posix
_temp = __import__(name, globals(), locals(), ['build_time_vars'], 0)
ModuleNotFoundError: No module named '_sysconfigdata__x86_64-linux-gnu'
Any clue, please?
