I’ve had a few problems trying to do a rebuild. I tried to restore from google backup after reinstalling Hassio but each time I try it prevents the webUI from loading.
I decided to rebuild my environment from the ground up reinstalling each add-on and configuring it from fresh… painful process.
The main problem I have encountered is trying to configure DuckDNS. I have my domain set up and the config looks as follows:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: my-token-id-value
domains:
- myDomainName.duckdns.org
seconds: 300
This issue occurs when I try to add my http details to configuration.yaml. As soon as I try to restart the box after adding these values the webUI won’t load. Fortunately I can remove the values via winSCP but I just can’t figure out what the problem is with them. I’ve checked in the ssl directory and both pem files are in there. The domain name appears to match what I set up on duckDNS (as does the token).
http:
# base_url: myDomainName.duckdns.org:8123
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
If I uncomment All or just 1 of the 3 values I get the problem with the webUI failing to load. The homeassistant.log doesn’t show anything to indicate a problem. The duckDNS log is as follows:
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[14:45:56] INFO: OK
212.159.89.102
NOCHANGE
Processing myDomainName.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Jun 20 19:13:00 2020 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
[14:51:12] INFO: OK
212.159.89.102
NOCHANGE
[14:56:13] INFO: OK
212.159.89.102
NOCHANGE
Anyone got any ideas? Is there a more detail log hidden somewhere that might give me a better insight into the problem?
Thanks in advance
