Hi all,
Hoping I can get some assistance with camera configuration. I have 2x cameras, they are model TrendNet IP311 (white labelled Hikvision 2132 basically). I’m trying to set them up using MJPEG as well as trying with just Generic and am having no luck. Here are the two configurations I have tried:
I’ve tried WGET’ing the image from my HA server (A Raspberry Pi 2) and it pulls it down okay, and obviously have hit the URLs with a browser to make sure it’s got the correct username and password. To be honest I’m dumbfounded, can anyone offer any tips?
Thanks for that, I’m fairly sure I have the URLs correct since I’m able to get the JPG and MJPEG to display in a browser and have pulled the JPG down from the Pi on the commandline okay. Really pulling my hair out on this one and can’t seem to find any error information in the logs (maybe I’m not looking in the right place?)
I was never able to use the Foscam component for my older Foscam 8918’s and had to resort to this URL with the generic MJPEG camera. While it will generate an error in the logs, it works perfectly.
Just a thought; many of the Chinese cams I have purchased were NOT set to http at the default port of 80; I assume you already checked this but if not… you’d have to alter the URL like so:
I’ve only seen this when I had trouble connecting to a camera - you can check that your URL provides a stream in a browser, but it already looks like you are connected.
Even if I could just hack the ui to click through to that URL it would be good (security wise not so many with the password in the URL) but at lease I could view it.
I had an old TrendNet cam that I couldn’t get to work for the longest time in HA and then I stumbled on this URL that seems to work. No promises, but it’s worth a try:
http://user:pass@CAM_IP/video/mjpg.cgi
I had a 7 month old post for support on that one that I was finally able to go back and close!
Thanks to you I got all my cameras working!! I was giving up on my TrendNet cameras in HA, but now everything works!! My cameras, my alarm… I am really happy!!! Thanks!!!
Hi I have setup a vivotek camera and streaming MJpeg on it on local network.
i added the camera mjpeg component for this and get it to display but only when clicking on the image.
if i close that image or try view as overview this is what i get. A small grey bar?
anyone know what causes this ?
