ok the story so far…
i watched a you tube video from Bruh showing how to build and use a multi sensor, after a lot of messing about (because I have no clue) and with help from someone on youtube i got the sensor built and the code loaded.
the following readings are from the sensor
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"41.40","motion":"motion detected","ldr":"205","temperature":"21.20","heatIndex":"20.46"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"41.40","motion":"motion detected","ldr":"0","temperature":"21.20","heatIndex":"20.46"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"41.40","motion":"motion detected","ldr":"89","temperature":"21.20","heatIndex":"20.46"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"41.40","motion":"motion detected","ldr":"7","temperature":"21.20","heatIndex":"20.46"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"41.40","motion":"motion detected","ldr":"7","temperature":"20.90","heatIndex":"20.13"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"573","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"608","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"466","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"402","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"433","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"518","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"476","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"415","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"42.80","motion":"motion detected","ldr":"328","temperature":"20.90","heatIndex":"20.16"}
{"state":"OFF","color":{"r":255,"g":255,"b":255},"brightness":255,"humidity":"43.90","motion":"motion detected","ldr":"22","temperature":"21.20","heatIndex":"20.52"}
after some help a few mins ago on here getting MQTT sorted i moved onto setting up the sensors in HA, however when i copy the code from BRUH into home assistant to configure it here i am hit with the imediate errors
and the sensors dont show the correct details.
the temp sensors say my house is at -5.5C even if I hold the sensor in my hands
light is 22LUX (not calibrated to LUX) no matter if I place it under a lamp or in a dark box
the PIR says there is motion detected even when placed in a dark box and not disturbed
the humidity however is working just fine
here is the code added
sensor.yaml
- platform: mqtt
state_topic: "bruh/sensornode1"
name: "SN1 Humidity"
unit_of_measurement: "%"
value_template: '{{ value_json.humidity | round(1) }}'
- platform: mqtt
##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
unit_of_measurement: "LUX"
value_template: '{{ value_json.ldr }}'
- platform: mqtt
value_template: '{{ value_json.motion }}'
- platform: mqtt
name: "SN1 Temperature"
unit_of_measurement: "°C"
value_template: '{{ value_json.temperature | round(1) }}'
- platform: mqtt
name: "SN1 Real Feel"
value_template: '{{ value_json.heatIndex | round(1) }}'
configuration.yaml
light:
- platform: mqtt_json
command_topic: "bruh/sensornode1/set"
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
groups.yaml
sensor_node_1_card:
name: Sensor Node 1
entities:
- sensor.sn1_temperature
- sensor.sn1_humidity
- sensor.sn1_ldr
- sensor.sn1_pir
- light.sn1_led
can anyone help me to display the correct details for the sensors?
thank you
