Having some potential problems with my network i’m unable to fix. Right now i’m not able to update anything on my Home Assistant Green. I get the following error.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:238
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:00:55 PM (1 occurrences)
Last logged: 12:00:55 PM
[281471976621376] Error updating Z-Wave JS UI: Can't install ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1/json: Not Found ("No such image: ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1")
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 167, in async_install
await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 53, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Can't install ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1/json: Not Found ("No such image: ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1")
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 238, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2149, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2186, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 272, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 882, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 952, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 161, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 465, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 169, in async_install
raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating Z-Wave JS UI: Can't install ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1/json: Not Found ("No such image: ghcr.io/hassio-addons/zwave-js-ui/aarch64:3.4.1")
Also of not my synology will not update packages as well, which leads me to thinking its a network problem. My network setup is cable modem > Deco mesh router > netgear prosafe JGS524PE switch. I’ve searched high and low and have done the usual things like setting up DNS to point to google. Does anyone have any suggestions for me? Thanks.
