I am very new to esphome and need a little help. I am trying to extract some data from a json api for temperature but I am having some issues. here is my code:
- http_request.get:
url: http://api.open-meteo.com/v1/forecast?latitude=0.00&longitude=0.00¤t=temperature_2m,wind_speed_10m
capture_response: true
on_response:
then:
- lambda: |-
json::parse_json(body, [](JsonObject root) -> bool {
id(temp_test).publish_state(root["current"]["temperature_2m"]);
return true;
when I flash my device (guition esp32-s3-4848s040) I get an error in the logs…
“Could not allocate memory for JSON document! Requested 0 bytes, free heap: 6291456”
here is what the json looks like
"latitude": 0,
"longitude": 0,
"generationtime_ms": 0.023961067199707,
"utc_offset_seconds": 0,
"timezone": "GMT",
"timezone_abbreviation": "GMT",
"elevation": 0,
"current_units": {
"time": "iso8601",
"interval": "seconds",
"temperature_2m": "°C",
"wind_speed_10m": "km/h"
"current": {
"time": "2024-09-30T14:45",
"interval": 900,
"temperature_2m": 25.2,
"wind_speed_10m": 13.7
If I try the same code but for a different website (http://wasab.is/json) which I saw on another post and I request (root[“latitude”) then I get no errors and temp_test is populated correctly.
Any help gratefully received !
Russ
