I’m new here so please excuse me if I ask questions in the wrong place.
I have successfully set up HA in docker (running on a linux server) and managed to connect to my KNX system. Next step for me was to set up SSL, but I cannot get it to work. The login screen shows up fine and I can inspect the SSL certificate from the browser, but after loggin in it says:
Unable to connect to Home Assistant. Retrying in 54 seconds…
My configuration looks like this:
Loads default set of integrations. Do not remove.
default_config:
frontend:
themes: !include_dir_merge_named themes
internal_url: https://repo.codeloft.se:8123
external_url: https://repo.codeloft.se:8123
http:
ssl_certificate: fullchain.pem
ssl_key: privkey.pem
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
knx:
switch:
- name: "Switch without passive addresses"
address: "0/7/1" # this is the address that will be sent to
state_address: "0/7/1" # this is the address GroupValueRead requests are sent to
Thank you!
