mikhul
(Mikael Hultin)
October 26, 2023, 12:41pm
1
Hi all!
This is my first post here, I have been reading a lot and getting great help, so here is hoping for more of the community goodness!
I am trying to read values from my CTC heat pump via Modbus and am struggling to get the values into Home Assistant. I can read the values using an external tool Modbus Poll, see picture:
However, I just cannot understand how to translate the above into configuration for Home Assistant. This is what I have so far:
- type: tcp
host: 192.168.1.187 # CTC EcoZenith i360
port: 502
delay: 5
timeout: 5
sensors:
- name: "CTC Aktuell rumstemp"
unique_id: ctc_current_room_temp
slave: 1
address: 62203
input_type: holding
unit_of_measurement: "°C"
device_class: temperature
state_class: measurement
data_type: int16
The sensor shows up but without values and is listed as unavailable.
I have other sensors set up using Modbus coming from my Solar inverter, so Modbus in general, is working.
Any ideas what I am doing wrong?
siggeb
(Sigurdur Birgisson)
November 26, 2024, 10:37pm
2
@mikhul did you sort it out? I have gotten the modbus integration configured, but I get some errors that its not connecting appropriately.
2024-11-26 23:33:36.768 DEBUG (MainThread) [pymodbus.logging] Connecting to 192.168.1.248:502.
2024-11-26 23:33:36.769 DEBUG (MainThread) [pymodbus.logging] Connecting comm
2024-11-26 23:33:36.773 DEBUG (MainThread) [pymodbus.logging] Connected to comm
2024-11-26 23:33:36.773 DEBUG (MainThread) [pymodbus.logging] Resetting frame - Current Frame in buffer -
2024-11-26 23:33:36.778 DEBUG (MainThread) [pymodbus.logging] -> transport: received eof
2024-11-26 23:33:36.778 DEBUG (MainThread) [pymodbus.logging] Connection lost comm due to None
2024-11-26 23:33:36.779 DEBUG (MainThread) [pymodbus.logging] callback_disconnected called: None
2024-11-26 23:33:36.779 DEBUG (MainThread) [pymodbus.logging] Wait comm 100.0 ms before reconnecting.
2024-11-26 23:33:36.823 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61500 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.824 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61503 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.824 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61509 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.824 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61513 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.824 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61517 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.824 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61521 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.824 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61542 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 61671 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62000 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62003 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62005 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62007 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62011 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62015 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62017 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.825 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62027 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.830 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62037 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.830 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62047 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62057 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62067 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62077 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62087 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62097 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62167 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.831 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62168 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.832 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62169 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.832 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62203 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.832 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62246 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.832 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62275 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.832 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62276 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.834 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62279 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.834 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62107 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62117 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62193 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62186 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62191 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62214 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62234 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62301 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62302 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 62303 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.835 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: ctc: Error: device: 1 address: 65001 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.248:502]
2024-11-26 23:33:36.880 DEBUG (MainThread) [pymodbus.logging] Connecting to 192.168.1.248:502.
I use this succesfully for quiet some time. However, I`m very annoyed that the register 62203 is only a holding register, I cannot write to it. Currently I use the room sensor from CTC itself. It’s an ass ugly device.
What I wanted to achieve is to use my Niko Home Control II display temperature sensor to update the current room temparature via modbus on the CTC, but so far I cannot get the job done as there is no register in the docs that allows me to do so.
CTC modbus register overview.
modbus:
- type: tcp
host: !secret ctc_ip
port: 502
sensors:
- name: CTC Outdoor Temperature
slave: 1
address: 62000
scan_interval: 300
unit_of_measurement: °C
scale: .1
- name: CTC Indoor Temperature
slave: 1
address: 62203
scan_interval: 300
scale: .1
- name: CTC Status
slave: 1
address: 62005
scan_interval: 300
