after just reading the community forum for month the time has come to ask the community for help: I have serious problems adding new devices to my setup. Also it seems that the z-wave network ist quite slow.
Devices spread around the whole house (several rooms and floors) with several non-battery-devices
Observations:
Changing heating modes changes the thermostat nearly immediately (1-2 seconds), but the changed setting is show in Home Assistant at the earliest after 5 seconds. This has been different before (other setup, maybe less devices, but it was possilble really immediately)
Some battery devices are showing 0% battery level even with new batteries. This happened before right after changing the batteries, but settled within the first day. Since some weeks the are several devices showing 0% all the time (some Eurotronic Spirit and one Fibaro Magic Eye)
Problem:
Including new devices does not work at all. Last success was including another SHRM10000 smoke detector. After including timed out, I waited some 10 seconds until a new (unidentified) device showed up. After some trying (re-interview, re-inserting battery, pushing buttons) the interview completed and the device showed up as wanted. I have some more devices that I cannot include in my setup (ABUS CFA3010, Sensative Strips Guard, ABUS SHRM10000, Fibaro FGS223)
There is not difference trying to include devices right next to the controller (basement) or from my working room.
I tried including a new SHRM10000 (debug log linked below). Including started at 18:57:39, at 18:57:50 the SHRM10000 stopped blinking (including completed?), at 18:59:10 Home Assistant including process ended with any information and after some more seconds a new device showed up in the list (node 128) with ânode statusâ=dead and ânode readyâ=no without any manufacturer/model information and without any entities (only entity node_status is deactivated)
So any idea what could be the problem here or how to debug this any further? The debug log can be found here.
Thx in advance for any help and/or advice!
Wolfgang
You have nodes sending constant power management reports. Looks like node 76 is reporting power every 5 seconds.
Seems like the network is being overwhelmed by these reports. What are those devices? Do you need those power reports or can you at least decrease their frequency?
Also, once you do get the issue straightened out, Iâd be sure to change logging back to âinfoâ. I left logging on and once I turned it off saw speed improve a lot.
Node 76 is the energy meter for the full house. Iâll reduce the reports to see if there is any effect.
I change the logging only on-demand in the integration configuration. For my understanding it is changed back to default âinfoâ once I leave the tab, or am I wrong with this?
Yeah I was having trouble with some energy monitoring switches, and things improved a lot when I disabled ones I donât need and decreased the frequency on others.
For the logging, I checked on the integration and changed to âinfoâ, closed the tab and app, and it was still info when I went back.
You want it just on âwarnâ during normal operation and not troubleshooting.
I changed the reporting intervals/tresholds to some higher values (less reporting) and changed the logging level at both integration and addon config to âwarnâ. Still the same problem trying to include a new SHRM10000: including stops without any result, several (~20-30) seconds later a new node shows up, âdeadâ and ânot readyâ. Exclusion does not work, therefore I have to remove the failed device and hard reset it.
My node id for new devices is at 130 now with 53 active devices, could this cause the problems?
Are there any recommendations for good working/good supported z-wave controllers? In the beginning I thought a GPIO device would be good but now I just want to have a working z-wave network.
Another silly log during normal operation (5mins). Seems not like too much traffic in my opinion, I still donât understand why inclusion is not working in my setup .
I also see some security errors on nodes 19 and 20, what are those? Have you changed your security key lately? Do they need security? You may need to remove and reinclude. You should include everything with no security unless itâs a door lock. S0 security uses a ton of bandwidth and should only be used if absolutely necessary.
This wonât impact anything. Zwave uses a 2 digit hex number for node idâs- 255 total numbers can be made with a 2 digit hex number. Once it cycles through all 250 some numbers sequentially, it will restart using old skipped ones.
There is a settings dump file in JSON format you can download
Once downloaded, do a search in the file for - â ânodeIdâ: 19 â
There will be a field under it isSecure = true, false, or unknown
If it says true or unkwown, the security isnât right and you should exclude and reinclude the device.
I know this must be frustrating. Generally, the way Iâve dealt with issues like yours is to try and remove devices that could potentially be causing problems from the network and see if things stabilize to narrow things down. Those are generally devices with too many log entries or errors in log entries. A device with security mismatch or wrong security will definitely cause issues throughout the network. Zwave is pretty low bandwith and bottlenecks impact the whole network. The problem is compounded usually because if commands donât make it sometimes devices âpanicâ and flood the network with even more commands.
Unfortunately though we canât rule out an issue/bug with the program itself, and there have been a lot of bugs around inclusion lately with zwavejs. It looks like you have the latest versions of everything to me. If ultimately you canât get any devices to include after troubleshooting and cleaning out problem devices/updating settings, youâll probably have to file a github issue. Start with filing it through Home Assistantâs github page first, since I donât know if the issue is the integration, addon, or zwavejs itself. Make sure you follow all the directions and attach any applicable logs.
My nodes were all âtrueâ or âunknownâ. Today I excluded every âtrueâ-device and re-included them. Now 6 devices are âfalseâ and 38 âunknownâ.
Main problem now: including more devices does not work anymore . Iâve put the devices back to their proper location now and will do a network heal for re-rerouting.
Iâll try to exclude some devices which I did not exlude today in the next days. If there is a faulty device affecting the whole network I hopefully will find it.
Sorry I should have been a little clearer on the âunknownâ- it really applied to the two thermostats since they were sending encapsulated messages and nonce reports- which is what securely included devices do. I wouldnât worry about the âunknownâ on other devices too much that arenât generating log issues.
Itâs weird you can exclude and reinclude devices that were already attached, but no additional new ones.
Does your heal ever complete successfully or does it just seem to get stuck?
You also may want to look into switching to the zwavejs2mqtt community addon instead. It gives you additional functionality including healing individual nodes vs the whole network, and itâs own control panel. I run it instead of the zwavejs addon.
Sry for the late response, Iâve been quite busy the last days. I did some more testing yesterday.
Iâm not even able the re-include all devices I excluded, Iâm still missing some thermostats. It seems to be quite luck, the including process in HA ends, but I cannot see the interview. In the node list there is a new e. g. ânode 156â, but âdeadâ or ânot readyâ. After a while the node is detected as expected. With my smart lock there has been some basic detection two weeks ago, yesterday I was not able the see it at all with several tries.
Iâve been using this in the beginning but changed to the official addon later as it supports all the features I need (including healing individual nodes by now) and because I wanted to assure that there are no compatibility issues at all. If I understand you correctly there should not be any difference in performance or compatiblilty, even more functionality.
I just ordered a Aeotec Z-Stick 7 which seems to be well supported with HA. If I have to remove every single device from my controller anyway for further troubleshooting I will use the opportunity to change from GPIO to USB and update to Z-Wave Gen7 for future use. Iâll let you know about my findings.
It still just sounds like a âtraffic jamâ or routing issue. Iâm not sure if a new zstick will fix the problem, but hopefully it helps, and whoâs like to hear how it goes.
What zwave hub were you on before Home Assistant? Did you have any issues with it or was everything working fine? A lot of times unresolved zwave issues just carry over.
As far as the whole zwavejs vs zwavejs2mqtt they continue to add more functions to the integration control panel, like heal node us there now, but its still not up to par with everything in zwavejs2mqtt. You canât set associations, canât do a custom/modified device config, or set custom parameters in the zwavejs control panel either.
I have to use zwavejs2mqtt since I use home assistant container so I donât have an option really (no included addons). However, if anyone with a hassio/supervised install asks if they should use zwavejs or zwavejs2mqtt , I would say zwavejs2mqtt. This is at least until everything is available to control and set directly though the zwavejs integration. Once that parity is achieved then it wonât really matter which one you use. If you donât need these extra features I agree, probably not worth switching an existing install, but if youâre starting over with a new zstick anyway, I would strongly consider it.
They also both use the same underlying zwavejs server, so there wouldnât be a compatibility issue. One could also argue the mqtt part of zwavejs2mqtt is a more universal standard that could better future proof your install versus using the websocket integration that just works only with Home Assistant.
yeah I still wonder why the logs do not show too much traffic or any further troubleshooting guidance/direction. Anyway Iâll give it a fresh start and hope there will be a single device which leads to instant lags rather than small problems with many devices of a kind.
I used openHAB for some years also with the RaZberry board. Not sure when the problems started (yes, I had them with openHAB also, but less devices and less problems) but I did a full re-include of all devices last year around the time I switched to HomeAssistant. But itâs a good hint, maybe I have to look after my âoldâ devices at first .
wow it has been a while, I had some other priorities to take care of .
In the meanwhile I changed the controller to a Aeotec Z-Stick 7/zwavejs2mqtt and added some devices. Quickly the ânetwork healâ was not succeeding any more, anyhow the performance of the network was still fine. So I reduced the number of devices again to find a setup, which with the ânetwork healâ will succeed. With only three Fibaro relays it was working. After adding two more relays (same model) the heal failed. Now I have a new setup with three different devices (no Fibaro), and it still fails, starting with a Aeotec Home Energy Meter.
Is there any other test I can perform to ensure network reliability and performance? I am afraid there is a generel problem with a device model unlike a single device, which will be hard to identify .
I just downgraded my 700 based stick to a 500 based Aeotek5+ last week. Still fighing a few minor issues but stuff isnât magically dropping anymoreâŚ
Update: Problems regarding including seem to be mostly solved with latest firmware for controller, FW: v7.19.2. Just in case anybody else has similar problems ;).
