Fresh deployment on a Hyper-V VM using haos_ova-6.2.vhdx
I’ve set 8.8.8.8 and 1.1.1.1 as DNS servers. my router is showing
If I type Login from the vm I can ping the 172.30.32.3 in the hosts when I run dns info
The below error just loops so Im a little stuck
21-08-19 23:21:00 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2021.8.8: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2021.8.8&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded")
21-08-19 23:21:00 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
Any help would be appreciated
