Hi
New to hass.io
I just installed it succesfully to my pi3b+
Then i installed pihole addon
Succesfully
Then i want to install the unifi addon so i can enter the pi’s ip adress
However
When launching unifi i get this error
cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] unifi.sh: executing…
[17:10:10] FATAL:
[17:10:10] FATAL: SSL has been enabled using the ‘ssl’ option,
[17:10:10] FATAL: this requires a SSL certificate file which is
[17:10:10] FATAL: configured using the ‘certfile’ option in the
[17:10:10] FATAL: add-on configuration.
[17:10:10] FATAL:
[17:10:10] FATAL: Unfortunately, the file specified in the
[17:10:10] FATAL: ‘certfile’ option does not exists.
[17:10:10] FATAL:
[17:10:10] FATAL: Please ensure the certificate file exists and
[17:10:10] FATAL: is placed in the Hass.io ‘/ssl/’ directory.
[17:10:10] FATAL:
[17:10:10] FATAL: In case you don’t have SSL yet, consider getting
[17:10:10] FATAL: a SSL certificate or setting the ‘ssl’ option
[17:10:10] FATAL: to ‘false’ in case you are not planning on using
[17:10:10] FATAL: SSL with this add-on.
[17:10:10] FATAL:
[17:10:10] FATAL: Check the add-on manual for more information.
[17:10:10] FATAL:
[cont-init.d] unifi.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
What do i need to do?
