Following on from this thread regarding problems with a fresh install, I seem to have got HAS installed on my Pi in a virtual env, as detailed here.
However, when I run hass
from within the virtual env, the first run never seems to complete and always ‘gets stuck’ at the same point. And I never get to the point where I can access my home assistance instance at http://<my-ip-addr>:8123
Ive left it for a much longer time than the forewarned 5-10 minutes in the guide. I actually left it for close to 1 hour.
Some configuration files exist at /home/homeassistant/.homeassistant
including a configuration.yaml
Am I missing something?
2018-09-13 13:59:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state sensor.yr_symbol=3; entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=3;content_type=image/png, attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol @ 2018-09-13T12:59:38.092928+00:00>, old_state=<state sensor.yr_symbol=unknown; entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png, attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol @ 2018-09-13T12:59:31.841610+00:00>, entity_id=sensor.yr_symbol>
2018-09-13 13:59:38 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-09-13 13:59:38 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 11.9 seconds.
2018-09-13 13:59:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>
a bit of device info incase this is releated to my Pi not being powerful enough…?..:
pi@smart-home-pi:~ $ cat /etc/debian_version
9.4
pi@smart-home-pi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@smart-home-pi:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 0010
Serial : 00000000c5562aff
