LuigiM81
(Mario Reisinger)
January 2, 2021, 11:55am
1
Hello there,
i try to send a value sensor.bad_raum_feuchtigkeit to modbus.
when i try in develpment - services - modbus.write_register
address: 9
unit: 255
hub: hub1
value: 17
everything works well, but
address: 9
unit: 255
hub: hub1
value: "{{ states('sensor.bad_raum_feuchtigkeit') | round }}"
doesn’t work.
Error: Fehler beim Aufrufen des Diensts modbus/write_register. expected int @ data['value'][0]
gives back the value 52 testet in templates…
What i’am doing wrong?
best regards Mario
Try conerting it to a float first:
value: "{{ states('sensor.bad_raum_feuchtigkeit') | float | round }}"
LuigiM81
(Mario Reisinger)
January 2, 2021, 1:51pm
3
Hello, thanks for the awnser - no it doesn’t work.
I’ve tried:
{{ states('sensor.bad_raum_feuchtigkeit') | int }}
{{ states('sensor.bad_raum_feuchtigkeit') | float }}
{{ states('sensor.bad_raum_feuchtigkeit') | float * 10 | round | int}}
{{ states('sensor.bad_raum_feuchtigkeit') | round | int }}
{{ states.sensor.bad_raum_feuchtigkeit | round }}
the second and third line are sending back xx.x all other xx - none of this are working.
Maybe you can’t template this key.
Can you try if this is the case with something like:
value: "{{ 12 * 10 }}"
LuigiM81
(Mario Reisinger)
January 2, 2021, 3:04pm
5
Burningstone:
alos doesn’t work
Error: modbus/write_register. expected int @ data['value'][0]
Is there another way to send this sensorvalue to modbus?
I don’t know, I’m not using modbus. Which version of Home Assistant are you running?
Did you try it from an automation instead of Developer Tools -> Services? Don’t think it makes any difference but would be worth a try.
LuigiM81
(Mario Reisinger)
January 2, 2021, 8:34pm
7
2020.12.7
I’ve started with some Codesnips out of the inet in automation and script but it doesen’t work, so i decided to start at basic - try to send manual. If this works i will automate it.
