Problems retrieving multiple values from one single rest call
hi, i have a question concerning the creation of multiple entities from one single rest call
I make a Post request to a slarmanpv endpoint to retrieve data from my solar system
when i try the following code it works fort one value
# rest api for solarman
### Solarman API ###
  - platform: rest
    resource: https://globalapi.solarmanpv.com/device/v1.0/currentData
    method: POST
    scan_interval: 3600
    headers:
      Authorization: bearer !secret solarmanpvtoken
      Content-Type: application/json
    payload: '{ "deviceId": "xxxxxxx", "deviceSn": "yyyyyyyyyyyyyy"}'
    name: "PVNord Cumulative Production kWh"
    unique_id : PVNordCumulativeProduction
    device_class: energy
    state_class: total_increasing
    unit_of_measurement: "kWh"
    value_template: "{{ value_json.dataList[46].value }}"
however, in the same call I want to retrieve also the values from
value_template: “{{ value_json.dataList[91].value }}”
value_template: “{{ value_json.dataList[92].value }}”
when I add a duplicate of the code, starting from - platform
it does not work
if a try to create a list of names like this
  - platform: rest
    method: POST
    scan_interval: 3600
    headers:
    payload: '{ "deviceId": "235111180", "deviceSn": "210213764DC1046300008"}'
    - name: "PVNord Cumulative Production kWh"
    - name: "PVNord new val1 kWh"
      unique_id : PVNordNewVal1
      value_template: "{{ value_json.dataList[91].value }}"
it doesn’t work either. I tried to check the documentation, but the different examples, ie with a single value, and multiple value seem to be build with different structures
the returned amount of data is quite long, more than 255 chars ( i saw somewhere that this is a limit to value templates and is like the following
    "code": null,
    "msg": null,
    "success": true,
    "requestId": "7351ttttttttt",
    "deviceSn": "2yyyyyyyyyyy",
    "deviceId": xxxxxxxxxxxxxxxxx,
    "deviceType": "INVERTER",
    "deviceState": 1,
    "collectionTime": 1730222284,
    "dataList": [
            "key": "SN1",
            "value": "xxxxxxxxxxxxxxxxx",
            "unit": null,
            "name": "SN"
            "key": "MMN",
            "value": "AUNISOL12KT",
            "unit": null,
            "name": "Machine Model (New)"
            "key": "ES_STA1",
            "value": "Germany",
            "unit": null,
            "name": "Marketing Electricity Standard"
the data to be extracted is in the different json’s in the datalist
You are confusing the rest sensor platform config with the rest integration config. Only the rest integration has the ability to make multiple sensors from the one call to the resource. Here is how you configure it for the integration:
### configuration.yaml, NOT sensors.yaml ###
rest:
  - resource: https://globalapi.solarmanpv.com/device/v1.0/currentData
    method: POST
    scan_interval: 3600
    headers:
Thanks,
i modofied my config.
but I think I do not get the corect data.
Is there any way to check the requests and the returned payload ?
Maybe I need to activazte some logs ?
Sorry, I am quit new to homeassistat
No there is no way to do that.
I did not check your value templates because you did not provide the full json data.
my json data looks like this
    "code": null,
    "msg": null,
    "success": true,
    "requestId": "bc3f14fbc1f9506d",
    "deviceSn": "21xxxxxx",
    "deviceId": 2yyyyyyyyy
    "deviceState": 1,
    "collectionTime": 1730294579,
    "dataList": [
            "key": "SN1",
            "value": "2102xxxxxxxxx,
            "unit": null,
            "name": "SN"
            "key": "MMN",
            "unit": null,
            "key": "ES_STA1",
            "value": "Germany",
            "unit": null,
            "key": "MODEi1",
            "value": "Input Independent Mode",
            "unit": null,
            "name": "Input Mode"
            "key": "SYSTIM1",
            "value": "2024-10-30 14:22:12",
            "unit": null,
            "name": "System Time"
            "key": "DSP2_VM",
            "value": "V1.2.1",
            "unit": null,
            "name": "DSP2 Version Number"
            "key": "DSPv1",
            "value": "V2.4.00",
            "unit": null,
            "name": "DSP Version"
            "key": "ARMv1",
            "value": "V2.0.00",
            "unit": null,
            "name": "ARM Version"
            "key": "UFB1",
            "value": "10",
            "unit": null,
            "name": "Upgrade Flag Bit"
            "key": "BAT_1_BMS_V",
            "value": "1.1258",
            "unit": null,
            "name": "Pack1-BMSVersion"
            "key": "BAT_2_BMS_V",
            "value": "1.1258",
            "unit": null,
            "name": "Pack2-BMSVersion"
            "key": "BAT_3_BMS_V",
            "value": "1.1258",
            "unit": null,
            "name": "Pack3-BMSVersion"
            "key": "BAT_4_BMS_V",
            "value": "",
            "unit": null,
            "name": "Pack4-BMSVersion"
            "key": "BAT_5_BMS_V",
            "value": "",
            "unit": null,
            "name": "Pack5-BMSVersion"
            "key": "BAT_6_BMS_V",
            "value": "",
            "unit": null,
            "name": "Pack6-BMSVersion"
            "key": "BAT_7_BMS_V",
            "value": "",
            "unit": null,
            "name": "Pack7-BMSVersion"
            "key": "BAT_8_BMS_V",
            "value": "",
            "unit": null,
            "name": "Pack8-BMSVersion"
            "key": "DV1",
            "value": "356.30",
            "unit": "V",
            "name": "DC Voltage PV1"
            "key": "DV2",
            "value": "566.40",
            "unit": "V",
            "name": "DC Voltage PV2"
            "key": "DC1",
            "value": "2.06",
            "unit": "A",
            "name": "DC Current PV1"
            "key": "DC2",
            "value": "2.00",
            "unit": "A",
            "name": "DC Current PV2"
            "key": "DP1",
            "value": "732",
            "unit": "W",
            "name": "DC Power PV1"
            "key": "DP2",
            "value": "1126",
            "unit": "W",
            "name": "DC Power PV2"
            "key": "DPi_t1",
            "value": "1858",
            "unit": "W",
            "name": "Total DC Input Power"
            "key": "ETLOTD",
            "value": "0.00",
            "unit": "Wh",
            "name": "Electricity To Load On The Day"
            "key": "RPBC",
            "value": "0.39",
            "unit": "A",
            "name": "R-phase Backup Current"
            "key": "RPBV",
            "value": "231.80",
            "unit": "V",
            "name": "R-phase Backup Voltage"
            "key": "RPBP",
            "value": "0",
            "unit": "W",
            "name": "R-phase Backup Power"
            "key": "SPBC",
            "value": "0.33",
            "unit": "A",
            "name": "S-phase Backup Current"
            "key": "SPBV",
            "value": "232.30",
            "unit": "V",
            "name": "S-phase Backup Voltage"
            "key": "SPBP",
            "value": "0",
            "unit": "W",
            "name": "S-phase Backup Power"
            "key": "TPBC",
            "value": "0.28",
            "unit": "A",
            "name": "T-phase Backup Current"
            "key": "TPBV",
            "value": "228.00",
            "unit": "V",
            "name": "T-phase Backup Voltage"
            "key": "TPBP",
            "value": "9",
            "unit": "W",
            "name": "T-phase Backup Power"
            "key": "AV1",
            "value": "231.80",
            "unit": "V",
            "name": "AC Voltage R/U/A"
            "key": "AV2",
            "value": "232.30",
            "unit": "V",
            "name": "AC Voltage S/V/B"
            "key": "AV3",
            "value": "228.00",
            "unit": "V",
            "name": "AC Voltage T/W/C"
            "key": "AC1",
            "value": "0.82",
            "unit": "A",
            "name": "AC Current R/U/A"
            "key": "AC2",
            "value": "0.81",
            "unit": "A",
            "name": "AC Current S/V/B"
            "key": "AC3",
            "value": "0.80",
            "unit": "A",
            "name": "AC Current T/W/C"
            "key": "A_Fo1",
            "value": "49.98",
            "unit": "Hz",
            "name": "AC Output Frequency R"
            "key": "A_Fo2",
            "value": "49.97",
            "unit": "Hz",
            "name": "AC Output Frequency S"
            "key": "A_Fo3",
            "value": "49.97",
            "unit": "Hz",
            "name": "AC Output Frequency T"
            "key": "AP1",
            "value": "-71",
            "unit": "W",
            "name": "AC Power R/U/A"
            "key": "AP2",
            "value": "-75",
            "unit": "W",
            "name": "AC Power S/V/B"
            "key": "AP3",
            "value": "-72",
            "unit": "W",
            "name": "AC Power T/W/C"
            "key": "Et_ge0",
            "value": "5451.10",
            "unit": "kWh",
            "name": "Cumulative Production (Active)"
            "key": "Etdy_ge1",
            "value": "8.20",
            "unit": "kWh",
            "name": "Daily Production (Active)"
            "key": "Emon1",
            "value": "369",
            "unit": "kWh",
            "name": "Monthly Production (Active)"
            "key": "Eyr1",
            "value": "1185",
            "unit": "kWh",
            "name": "Yearly Production (Active)"
            "key": "ST_PG1",
            "value": "Purchasing energy",
            "unit": null,
            "name": "Grid Status"
            "key": "PG_V1",
            "value": "231.80",
            "unit": "V",
            "name": "Grid Voltage R/U/A"
            "key": "PG_V2",
            "value": "232.30",
            "unit": "V",
            "name": "Grid Voltage S/V/B"
            "key": "PG_V3",
            "value": "228.10",
            "unit": "V",
            "name": "Grid Voltage T/W/C"
            "key": "PG_F1",
            "value": "49.98",
            "unit": "Hz",
            "name": "Grid Frequency"
            "key": "PG_Pt1",
            "value": "-2036",
            "unit": "W",
            "name": "Total Grid Power"
            "key": "t_gc1",
            "value": "388.40",
            "unit": "kWh",
            "name": "Cumulative Grid Feed-in"
            "key": "Et_pu1",
            "value": "4128.20",
            "unit": "kWh",
            "name": "Cumulative Energy Purchased"
            "key": "t_gc_tdy1",
            "value": "0.00",
            "unit": "kWh",
            "name": "Daily Grid Feed-in"
            "key": "Etdy_pu1",
            "value": "36.0",
            "unit": "kWh",
            "name": "Daily Energy Purchased"
            "key": "t_gc_tdy2",
            "value": "4",
            "unit": "kWh",
            "name": "Monthly Grid Feed-in"
            "key": "Etdy_pu2",
            "value": "1395",
            "unit": "kWh",
            "name": "Monthly Energy Purchased"
            "key": "t_gc_tdy3",
            "value": "23",
            "unit": "kWh",
            "name": "Yearly Grid Feed-in"
            "key": "Etdy_pu3",
            "value": "2418",
            "unit": "kWh",
            "name": "Yearly Energy Purchased"
            "key": "E_B_D",
            "value": "0.00",
            "unit": "kWh",
            "name": "Daily Energy Buy"
            "key": "GRID_C_D",
            "value": "0.00",
            "unit": "kWh",
            "name": "Same Day Grid Connection"
            "key": "RPMC",
            "value": "3.93",
            "unit": "A",
            "name": "R-phase Meter Current"
            "key": "SPMC",
            "value": "1.74",
            "unit": "A",
            "name": "S-phase Meter Current"
            "key": "TPMC",
            "value": "5.20",
            "unit": "A",
            "name": "T-phase Meter Current"
            "key": "RPMP",
            "value": "-801",
            "unit": "W",
            "name": "R-phase Meter Power"
            "key": "SMP",
            "value": "-290",
            "unit": "W",
            "name": "S-phase Meter Power"
            "key": "TMP",
            "value": "-945",
            "unit": "W",
            "name": "T-phase Meter Power"
            "key": "S_F1",
            "value": "49.98",
            "unit": "Hz",
            "name": "S-phase grid frequency"
            "key": "T_F1",
            "value": "49.98",
            "unit": "Hz",
            "name": "T-phase grid frequency"
            "key": "E_Puse_t1",
            "value": "1825",
            "unit": "W",
            "name": "Total Consumption Power"
            "key": "E_Puse1",
            "value": "730",
            "unit": "W",
            "name": "Consumption Active Power R"
            "key": "E_Puse2",
            "value": "212",
            "unit": "W",
            "name": "Consumption Active Power S"
            "key": "E_Puse3",
            "value": "883",
            "unit": "W",
            "name": "Consumption Active Power T"
            "key": "Et_use1",
            "value": "8947.50",
            "unit": "kWh",
            "name": "Cumulative Consumption"
            "key": "Etdy_use1",
            "value": "27.10",
            "unit": "kWh",
            "name": "Daily Consumption"
            "key": "Etdy_use2",
            "value": "1724",
            "unit": "kWh",
            "name": "Monthly Consumption"
            "key": "Etdy_use3",
            "value": "3503",
            "unit": "kWh",
            "name": "Yearly Consumption"
            "key": "B_ST1",
            "value": "Charging",
            "unit": null,
            "name": "Battery Status"
            "key": "BN_1",
            "value": "LFP5.1K",
            "unit": null,
            "name": "Battery name"
            "key": "B_V1",
            "value": "56.51",
            "unit": "V",
            "name": "Battery Voltage"
            "key": "B_C1",
            "value": "-35.10",
            "unit": "A",
            "name": "Battery Current"
            "key": "L_Vdcg1",
            "value": "43.20",
            "unit": "V",
            "name": "Discharging Cut-off Voltage"
            "key": "Ccg_max1",
            "value": "36",
            "unit": "A",
            "name": "Max. Charging Current"
            "key": "Cdcg_max1",
            "value": "150",
            "unit": "A",
            "name": "Max. Discharging Current"
            "key": "B_P1",
            "value": "-1983",
            "unit": "W",
            "name": "Battery Power"
            "key": "B_left_cap1",
            "value": "99.00",
            "unit": "%",
            "name": "SoC"
            "key": "t_cg_n1",
            "value": "1651",
            "unit": "kWh",
            "name": "Total Charging Energy"
            "key": "t_dcg_n1",
            "value": "1533",
            "unit": "kWh",
            "name": "Total Discharging Energy"
            "key": "Etdy_cg1",
            "value": "17.10",
            "unit": "kWh",
            "name": "Daily Charging Energy"
            "key": "Etdy_dcg1",
            "value": "0.00",
            "unit": "kWh",
            "name": "Daily Discharging Energy"
            "key": "D_C_E",
            "value": "0.00",
            "unit": "kWh",
            "key": "D_D_E",
            "value": "0.00",
            "unit": "kWh",
            "key": "NBP",
            "value": "3",
            "unit": null,
            "name": "Number Of Battery Packs"
            "key": "BCCSV",
            "value": "160",
            "unit": "A",
            "name": "Battery Charge Current Set Value"
            "key": "BCV",
            "value": "56.60",
            "unit": "V",
            "name": "Battery Charging Voltage"
            "key": "BCPS",
            "value": "100",
            "unit": "%",
            "name": "Battery Charge Power Scheduling (grid)"
            "key": "BRC",
            "value": "300",
            "unit": "Ah",
            "name": "Battery Rated Capacity"
            "key": "BDPS",
            "value": "80",
            "unit": "%",
            "name": "Battery Discharge Power Scheduling"
            "key": "TCS",
            "value": "Non-Timed Charging And Non-Timed Discharge",
            "unit": null,
            "name": "Timed Charge/discharge State"
            "key": "FCDPE",
            "value": "Invalid",
            "unit": null,
            "name": "Forced Charge And Discharge Power Enable"
            "key": "BMS_D_O_D_E",
            "value": "0",
            "unit": null,
            "name": "BMS Depth Of Discharge Enable"
            "key": "O_G_D_O_D",
            "value": "95",
            "unit": "%",
            "name": "Off-Grid Battery Depth Of Discharge"
            "key": "M_C_M_SOC",
            "value": "100",
            "unit": "%",
            "name": "Mains Charging Maximum SOC"
            "key": "M_M_SOC_E",
            "value": "1",
            "unit": null,
            "name": "Maintain Minimum SOC Enable"
            "key": "PC1_MT",
            "value": "32.00",
            "unit": "℃",
            "name": "Battery pack 1cell maximum temperature"
            "key": "BAT_1_V",
            "value": "56.36",
            "unit": "V",
            "name": "Battery pack 1 Voltage"
            "key": "BAT_1_HS",
            "value": "Heater OFF",
            "unit": null,
            "name": "Battery Pack 1 Heater Status"
            "key": "P1ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 1"
            "key": "P1PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 1"
            "key": "P1FSB1",
            "value": "8,10,11,13",
            "unit": null,
            "name": "Pack1 Fault State Battery 1"
            "key": "PC2_MT",
            "value": "31.00",
            "unit": "℃",
            "name": "Battery pack 2 cell maximum temperature"
            "key": "BAT_2_V",
            "value": "56.27",
            "unit": "V",
            "name": "Battery pack 2 Voltage"
            "key": "BAT_2_HS",
            "unit": null,
            "name": "Battery Pack 2 Heater Status"
            "key": "P2ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 2"
            "key": "P2PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 2"
            "key": "P2FSB1",
            "unit": null,
            "name": "Pack1 Fault State Battery 2"
            "key": "PC3_MT",
            "value": "33.80",
            "unit": "℃",
            "name": "Battery pack 3 cell maximum temperature"
            "key": "BAT_3_V",
            "value": "56.42",
            "unit": "V",
            "name": "Battery pack 3 Voltage"
            "key": "BAT_3_HS",
            "unit": null,
            "name": "Battery Pack 3 Heater Status"
            "key": "P3ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 3"
            "key": "P3PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 3"
            "key": "P3FSB1",
            "unit": null,
            "name": "Pack1 Fault State Battery 3"
            "key": "PC4_MT",
            "value": "0.00",
            "unit": "℃",
            "name": "Battery pack 4 cell maximum temperature"
            "key": "BAT_4_V",
            "value": "0.00",
            "unit": "V",
            "name": "Battery pack 4 Voltage"
            "key": "BAT_4_HS",
            "unit": null,
            "name": "Battery Pack 4 Heater Status"
            "key": "P4ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 4"
            "key": "P4PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 4"
            "key": "P4FSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Fault State Battery 4"
            "key": "PC5_MT",
            "value": "0.00",
            "unit": "℃",
            "name": "Battery pack 5 cell maximum temperature"
            "key": "BAT_5_V",
            "value": "0.00",
            "unit": "V",
            "name": "Battery pack 5 Voltage"
            "key": "BAT_5_HS",
            "unit": null,
            "name": "Battery Pack 5 Heater Status"
            "key": "P5ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 5"
            "key": "P5PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 5"
            "key": "P5FSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Fault State Battery 5"
            "key": "PC6_MT",
            "value": "0.00",
            "unit": "℃",
            "name": "Battery pack 6 cell maximum temperature"
            "key": "BAT_6_V",
            "value": "0.00",
            "unit": "V",
            "name": "Battery pack 6 Voltage"
            "key": "BAT_6_HS",
            "unit": null,
            "name": "Battery Pack 6 Heater Status"
            "key": "P6ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 6"
            "key": "P6PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 6"
            "key": "P6FSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Fault State Battery 6"
            "key": "P7ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 7"
            "key": "P7PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 7"
            "key": "P7FSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Fault State Battery 7"
            "key": "PC7_MT",
            "value": "0.00",
            "unit": "℃",
            "name": "Battery pack 7 cell maximum temperature"
            "key": "BAT_7_V",
            "value": "0.00",
            "unit": "V",
            "name": "Battery pack 7 Voltage"
            "key": "BAT_7_HS",
            "unit": null,
            "name": "Battery Pack 7 Heater Status"
            "key": "P8ASB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Alarm State Battery 8"
            "key": "P8PSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Protect State Battery 8"
            "key": "P8FSB1",
            "value": "",
            "unit": null,
            "name": "Pack1 Fault State Battery 8"
            "key": "PC8_MT",
            "value": "0.00",
            "unit": "℃",
            "name": "Battery pack 8 cell maximum temperature"
            "key": "BAT_8_V",
            "value": "0.00",
            "unit": "V",
            "name": "Battery pack 8 Voltage"
            "key": "BAT_8_HS",
            "unit": null,
            "name": "Battery Pack 8 Heater Status"
            "key": "B_T1",
            "value": "31.90",
            "unit": "℃",
            "name": "Temperature- Battery"
            "key": "RT_I",
            "value": "56.30",
            "unit": "℃",
            "name": "Inverter radiator temperature"
            "key": "RT_B",
            "value": "54.40",
            "unit": "℃",
            "name": "Battery radiator temperature"
            "key": "CIT",
            "value": "58.40",
            "unit": "℃",
            "name": "Chassis Internal Temperature"
            "key": "T_PV",
            "value": "55.40",
            "unit": "℃",
            "name": "PV Temperature"
            "key": "T_LLC",
            "value": "54.10",
            "unit": "℃",
            "name": "LLC Temperature"
            "key": "WEEK",
            "value": "3",
            "unit": null,
            "name": "Week"
            "key": "NUM_gird_conn1",
            "value": "796",
            "unit": null,
            "name": "Grid-tied Times"
            "key": "DCBUS",
            "value": "675.80",
            "unit": "V",
            "name": "Dcbus Voltage"
            "key": "PD",
            "value": "60",
            "unit": "S",
            "name": "Power On Delay"
            "key": "Bus_V1",
            "value": "735.40",
            "unit": "V",
            "name": "Bus Voltage"
            "key": "INV_ST1",
            "value": "Grid connected",
            "unit": null,
            "name": "Inverter status"
            "key": "RSS",
            "value": "Normal",
            "unit": null,
            "name": "Remote Shutdown Status"
            "key": "SS1",
            "value": "Hybrid Grid Connection",
            "unit": null,
            "name": "System Status"
            "key": "SAS",
            "value": "Self-consumption",
            "unit": null,
            "name": "System Application Scenario"
            "key": "DS",
            "value": "Discharge Mode",
            "unit": null,
            "name": "Dcdc Status"
            "key": "N_S_1",
            "value": "1",
            "unit": null,
            "name": "Network Status 1"
            "key": "N_S_2",
            "value": "1",
            "unit": null,
            "name": "Network Status 2"
            "key": "N_S_3",
            "value": "1",
            "unit": null,
            "name": "Network Status 3"
            "key": "N_S_4",
            "value": "0",
            "unit": null,
            "name": "Network Status 4"
            "key": "N_S_5",
            "value": "0",
            "unit": null,
            "name": "Network Status 5"
            "key": "N_S_6",
            "value": "0",
            "unit": null,
            "name": "Network Status 6"
            "key": "N_S_7",
            "value": "0",
            "unit": null,
            "name": "Network Status 7"
            "key": "N_S_8",
            "value": "0",
            "unit": null,
            "name": "Network Status 8"
            "key": "DSP_ERR2",
            "value": "",
            "unit": null,
            "name": "DSP Alarm Codes"
            "key": "ARM_ERR2",
            "value": "",
            "unit": null,
            "name": "ARM Alarm Code"
            "key": "DSP_ERR3",
            "value": "",
            "unit": null,
            "name": "DSP Error Codes"
            "key": "SV_F",
            "value": "1.00",
            "unit": null,
            "name": "Function Setting Values"
            "key": "SV_A",
            "value": "100",
            "unit": "%",
            "name": "Active Setting Values"
            "key": "SV_R",
            "value": "0",
            "unit": "%",
            "name": "Reactive Setting Values"
            "key": "RCM",
            "value": "According To Power Factor Control",
            "unit": null,
            "name": "Reactive Control Method"
            "key": "WBE",
            "value": "Enable",
            "unit": null,
            "name": "Wake-up Bms Enable"
            "key": "WTS",
            "value": "60",
            "unit": "min",
            "name": "Wake-up Time Setting"
            "key": "B_D_cap1",
            "value": "80",
            "unit": "%",
            "name": "Battery Discharge Capacity Depth"
and I need some of the values in the datalist arry. best would be to find them with the key, so I would be independant of a future reordering of the list. for now I am looking up with index ( 46, 91 and 92)
Did you edit that?
Because it is not valid json.
No, this is what i get when trying the call with Postman
Then that’s your problem. It is not valid json.
And I have a new question . The token expires ever month, so it is possible to store a returned value in a variable, and use it in the yaml file ?
so in this part
rest:
    method: POST
    scan_interval: 900
    headers:
      Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1c2VyX25hbWUiOiIwX3NvbGFybWFuQGR1cmJhY2guY2xxxxxxxxx
n7pbG1YA0L_o3MW71NgVuQPkw
the value of the bearer should come from a variable
and in this call
- resource: https://globalapi.solarmanpv.com/account/v1.0/token?appId=302vvvvvvv1526
    method: POST
    scan_interval: 92592000
    headers:
    payload: '{"appSecret": "6cab5cccccc7a79a9b3","email": "[email protected]","password": "password"}'
      - name: "SolarmanpvToken"
        unique_id : Solarmanpvtoken
        value_template: "{{ value_json.accesstoken.value }}"
the value of the sensor should be stored in a variable
Or, in the first call, the value of the bearer should comm directly from sensor.Solarmanpvtoken
Problem here is tat the state can’t hold ore than 225 chars which is not enough for the token value which has a legth og neraly 900 chars.
Is there any vaild solution here ?
Use an attribute. They can store more than 255 chars.
