I’m fairly new to this, but I was able to get the hue lights up and running without much difficulty. However, I can’t get HA to see my nest thermostats. Actually, there are two.
Here is the relevant part of my config file;
Am I missing anything? Edit: there are actually indents in my config file, haven’t figured out how to get them in the post.
Use the < / > symbol in the tool bar for posting code
You can use the structure variable to define more than one. https://home-assistant.io/components/nest/
If your nest account has these added then they should be included by default.
