I am trying to setup haaska and I have run in to an issue in the Setting up AWS Lambda - Part 2, the instructions starting with step 5 through step 7 states
In the “Function code” section, look for “Code entry type”. Click on this menu, and select “Upload a .zip file”.
Click the “Upload” button, and select the zip file we downloaded earlier (e.g. haaska_1.1.0.zip ).
In the “Handler” box, replace what is already there with “haaska.event_handler”.
The problem is I don’t have a Code entry type, or a Handler box, I can upload the file but then I get an error “lambada_function.py does not exist” and I can not move on any further. I am looking for what to do to get beyond this, I can go on and get everything else configured but the function will not work without the lambada_function.py. I assume the handler part of the instructions overrides this but since I don’t have that option I am back to square one. I have tried doing the config on three different PCs in a total of five different browsers and they are all the same.
Thanks for any assistance in advance and I am happy to provide any missing information.
Not sure I’ll be helpful, but after you upload the zip file, do the files and folders show up in the “Function code” sheet, along with a couple of tabs for haaska.py and config.json? If not, I’m wondering if the zip file is corrupted?
wmaker Thanks for responding, Yes the haaska.py and config.json are present, here is a screen shot, the only thing you can not see in the screen shot is the spinning wheel in the “lambada_function” tab because there is not a lambada_function.
Oh that’s not good . No real clues. As a guess, when you uploaded the zip file, did it by chance ask you what the programming language was like python3.6 ?
