Hey all,
I decided to uninstall pi-hole as its depreciated and give adguard a go. Since I uninstalled pihole the addon store fails to successfully install anything with an error ‘Failed to install addon, Unknown Error, see logs’
In the logs I am getting:
20-03-31 22:42:51 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image hassioaddons/adguard-amd64 tag 2.3.3.
20-03-31 22:42:51 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install hassioaddons/adguard-amd64:2.3.3 → 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:60490->[::1]:53: read: connection refused”).
Seems like I’ve buggered DNS and I am not sure how to fix it, any suggestions?
