zigbee stick is conbee 2 → i use a 5 meter extesion USB cable to put the stick devices in living room .
install deCONZ on home assist
install ZHA
At this moment i have 2 products working under Home assit with ZHA
1: Aqara motion sensor
2: Aqara door\window sensor
Now i want to put one new product to the list.
1: Aqara p1 motion Sensor
Now the product i find it in HA only i see it is not connect to te coordinator conbee 2 stick.
see photo
Curious if you will get the answer. As i have kind of the same.
Googled but couldn’t find an answer.
I have home assistant on raspberry pi, conbee 2 stick and zha installed. 3 aqara sensors are working on zha. But the P1 motion sensor does not. If I press the pairing button home assistant sees it. But if there is motion nothing happens.
Will check your post to see if it can help me.
