Problems using Home Assistant Settings / Update functionality to update reolink camera
Under the Setting Updates at the top of the page I keep getting this on a new driver to install
Camera Front Doorbell Firmware
6 minutes ago
Update available
Installed version
v3.0.0.3215_2401262241
Latest version
v3.0.0.3308_2407315183
Read release announcement
If the install button fails, download this firmware zip file. Then, follow the installation guide (PDF in the zip file).
Release notes
If I try to run this I get this error
Tip! Join the community on our Forums, X (formerly Twitter), Chat, Blog or Newsletter
Failed to perform the action update/install. Error trying to update Reolink firmware: Reolink device could not find new firmware, try downloading from the Reolink download center (Download Center – Reolink) and update manually
I am also using the reolink App that I am also using
In that UI click on the gear associated with this specific camera
and click on the menues
System / Maintance / firmware update / Check for Latest Version
It says The Most current version is installed
I have tried to install several times with or without the Reolink app running or haveing been run before it with the same results
I am confused to what you are trying to install here when it says the most current version from reolink is currently installed
The reolink camera showes the current version identical to what you Home Assistant says on this update screen
Just figured I would report this after researching it.
Output from
Settings > System > Repairs > Three dots in the upper right > System information
System Information
version core-2024.10.3
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.12.4
os_name Linux
os_version 6.6.54-haos
arch x86_64
timezone America/Denver
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
HACS Data ok
GitHub API Calls Remaining 5000
Installed Version 2.0.1
Stage running
Available Repositories 1451
Downloaded Repositories 15
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 13.2
update_channel stable
supervisor_version supervisor-2024.10.3
agent_version 1.6.0
docker_version 27.2.0
disk_total 234.0 GB
disk_used 12.1 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board generic-x86-64
supervisor_api ok
version_api ok
installed_addons ESPHome (2024.10.2), Mosquitto broker (6.4.1), Samba share (12.3.2), Studio Code Server (5.17.2), Z-Wave JS (0.8.1), Terminal & SSH (9.15.0), Duck DNS (1.18.0), Node-RED (18.1.1), Cloudflared (5.1.22), Advanced SSH & Web Terminal (19.0.0), Home Assistant Google Drive Backup (0.112.1), Z-Wave JS UI (3.16.0), MariaDB (2.7.1), File editor (5.8.0), Google Assistant SDK (2.5.0), Matter Server (6.6.0)
Dashboards
dashboards 9
resources 6
views 11
mode storage
Recorder
oldest_recorder_run October 16, 2024 at 3:23 AM
current_recorder_run October 25, 2024 at 9:09 AM
estimated_db_size 139.19 MiB
database_engine mysql
database_version 10.11.6
I don’t have a solution but I am experiencing the same behaviour.
I am having a similar issue, but I believe Home Assistant is incorrectly detecting the firmware version.
On my Reolink desktop client and Reolink android app, I see a firmware version of v3.4.0.293_24010837, but HA shows v3.0.0.388_21062101.
Maybe this is related to the fact that I only connect my NVR, and all the cameras are connected to HA “via NVR”.
Edit: Nevermind, the Reolink client is kind of confusing looking at NVR firmware vs Camera firmware and I was misreading it.
