I had to setup my new esphome installation.
I installed:
python 3.10.5
wheel 0.37.1
PIO Core 5.2.5
pip 22.0.4
esphome 2022.5.1
After installing wheel, the system told me to update pip to version 22.2.
After doing this I tried to upload a Yaml-file that has been uploaded sucessfull in the previous installation.
Then I was told by the system to install the pillow Python package to use the feature "font: ".
After installing pillow the system told me that the PIO Core ist obsolate and upgrade to 6.0.2.
This leads me to an errors that esphome is incompatible with PIO Cor 6.0.2.
After downgrade to the previous version I now run PIO Core 5.2.5 again
Trying to upload a yaml-file again the system tells me, that an obsolate PIO Coreis used and to remove multiple PIO Cores from a system.
A long errorlist ends with:
An unexpected error occurred. Further steps:
Verify that you have the latest version of PlatformIO using
pip install -U platformiocommand -
Try to find answer in FAQ Troubleshooting section
Redirecting... -
Report this problem to the developers
Issues · platformio/platformio-core · GitHub
Then I do “pip install -U platformio” with the error
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
esphome 2022.5.1 requires platformio==5.2.5, but you have platformio 6.0.2 which is incompatible.
What can/should I do?
Eberhard
