Problems with Area pictures
I’m adding photos to my Areas, and the photos aren’t displaying after upload.
After I select the cropping of the photo I intend to use, it acts like it uploads, but then the photo for that particular Area is a black square. I wanted to check on the file, but I have no clue where Area saves the file.
Based on timestamps, it looks like it might be saving to config/image, but there are not actual image files in there. Just two files in each folder that’s there… 512x512 and original. Each file has no extension and none seem large enough in file size to be images.
Thoughts on where to start troubleshooting?
I have same issue… but if I change in android, works fine and crop
Same! On both MacOS and OSx.
