I have a problem with the CalDAV integration. I am trying to import an iCloud calendar. Unfortunately, this works very unreliably. Several times per hour I get the error message in the user interface ‘Error while fetching calendar. Response error: 400’. Sometimes even 500.
The log file says :
homeassistant | 2024-10-03 21:43:45.576 ERROR (SyncWorker_39) [root] ---
homeassistant | +++
homeassistant | @@ -5,7 +5,6 @@
homeassistant | BEGIN:VEVENT
homeassistant | DTSTAMP:20241003T214345Z
homeassistant | CREATED:20230910T173836Z
homeassistant | -DTSTAMP:20230910T173837Z
homeassistant | SEQUENCE:0
homeassistant | SUMMARY:Geburtstag Estelle
homeassistant | UID:7EAC0253-F358-42C4-B7D0-5EC78B867C14
homeassistant | 2024-10-03 21:47:48.892 ERROR (MainThread) [aiohttp.server] Error handling request
homeassistant | Traceback (most recent call last):
homeassistant | File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 462, in _handle_request
homeassistant | resp = await request_handler(request)
homeassistant | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 537, in _handle
homeassistant | 2024-10-03 21:48:50.568 ERROR (MainThread) [aiohttp.server] Error handling request
homeassistant | resp = await handler(request)
homeassistant | File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
homeassistant | return await handler(request)
homeassistant | File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
homeassistant | File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
homeassistant | File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
homeassistant | File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
homeassistant | File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
homeassistant | File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
homeassistant | response = await handler(request)
homeassistant | File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
homeassistant | result = await handler(request, **request.match_info)
homeassistant | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 648, in get
homeassistant | calendar_event_list = await entity.async_get_events(
homeassistant | File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 200, in async_get_events
homeassistant | File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
homeassistant | result = self.fn(*self.args, **self.kwargs)
homeassistant | File "/usr/local/lib/python3.12/site-packages/caldav/objects.py", line 1079, in search
homeassistant | (response, objects) = self._request_report_build_resultlist(
homeassistant | File "/usr/local/lib/python3.12/site-packages/caldav/objects.py", line 958, in _request_report_build_resultlist
homeassistant | response = self._query(xml, 1, "report")
homeassistant | File "/usr/local/lib/python3.12/site-packages/caldav/objects.py", line 216, in _query
homeassistant | raise error.exception_by_method[query_method](errmsg(ret))
homeassistant | caldav.lib.error.ReportError: ReportError at '503 Service Unavailable
homeassistant |
homeassistant | b''', reason no reason
Sometimes everything is displayed correctly and then an error message appears again with the next update.
Information about my system:
- HomeAssistant 2024-9-3
- running on Docker
- I configured the calendar with the UI (not in yaml)
- I added an app-specific password
Does anyone know the problem? Any tips on how I can fix this?
