I am trying to send the command “PWR OFF” to my projector. I tried bot these commands:
'echo "PWR ON\r" | nc 192.168.1.33 4999'
'echo -e "PWR OFF\r" | nc 192.168.1.33 4999'
But neither works.
This other command works fine:
'echo "9120a" | nc 192.168.1.210 23'
So i think the problem is with the command itself, not the echo-function itself.
wmaker
(Tommy Long)
2
Maybe try using ‘\n’ instead of ‘\r’
Thanks, tried that but doesn’t seem to work either.
I tried using putty, and a “raw” connection, with the following parameters:
192.168.1.33:4999
Then i wrote PWR ON and hit enter in the terminal. That worked fine. So i think i am doing something wrong with the carrige return part in HA.
wmaker
(Tommy Long)
5
maybe one of these will work:
- \n\n
- \r\n
- \r\n\r\n
Thanks, I tried all three, with our with -e and none seemed to work.
