I have been getting these error messages lately and some devices are not responding
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[10:40:31] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[10:40:34] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:error 2022-04-05 10:41:04: Publish 'set' 'system_mode' to 'Thermostat Badezimmer' failed: 'Error: Command 0xcc86ecfffec1f822/1 manuSpecificTuya.dataRequest({"seq":1,"dpValues":[{"dp":101,"datatype":1,"data":[1]}]}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
Zigbee2MQTT:error 2022-04-05 10:41:04: Publish 'set' 'system_mode' to 'Thermostat Wohnzimmer' failed: 'Error: Command 0x5c0272fffec61b0a/1 manuSpecificTuya.dataRequest({"seq":0,"dpValues":[{"dp":101,"datatype":1,"data":[1]}]}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
I am assuming that the CC2652P2 died. I had a similar issue with the older CC2531. If so, it is really annyoing. Maybe I should buy the original Conbee II or Raspbee II.
Any ideas?
Any other ideas?
