I am having very strange effects with comments and have tried everything I could come up with. The code below works just fine in the template editor and it compiles also. But the sensor has the state “unavailable”. If I remove all comments, it works fine.
What am I missing about the comments?
- sensor:
# Name of the sensor
- name: "Pellet_Usage_Difference"
# Unique identifier for the sensor
unique_id: e7900b1b-e89b-4356-a050-a6928781042f
# Icon representing the sensor
icon: mdi:weight-kilogram
# Unit of measurement for the sensor value
unit_of_measurement: "kg"
state: >-
{# Get pellet count at midnight, default to 0 #}
{% set gewicht_start = states('input_number.pelletsatmidnight') | float(0) %}
{# Get current pellet usage, default to 0 #}
{% set gewicht_end = states('sensor.solarfocus_biomass_boiler_pellet_usage_total') | float(0) %}
{# Check if the current usage is zero or the sensor is unavailable #}
{% if gewicht_end == 0 or
is_state('sensor.solarfocus_biomass_boiler_pellet_usage_total', 'unavailable') or
is_state('sensor.solarfocus_biomass_boiler_pellet_usage_total', 'unknown') %}
{# Return 0 if any conditions are met #}
0
{% else %}
{# Calculate the difference and ensure it's at least 0 #}
{{ max(0, (gewicht_end - gewicht_start) | round(2)) }}
{% endif %}
availability: >
# Check if the sensor is available (not unknown or unavailable)
{{ states('sensor.solarfocus_biomass_boiler_pellet_usage_total') not in ['unknown', 'unavailable'] }}
