**Home Assistant Android app version(s):**
**Android version(s):** 2025.12.3-fu…ll
**Device model(s):** OnePlus 10 Pro
**Home Assistant version:** 2025.12.3
**Last working Home Assistant release (if known):** 2023.12.3
**Description of problem, include YAML if issue is related to notifications:**
For the past two days, the companion app has been unable to update any of the sensors associated with my phone in home assistant, including the location sensor, whenever I am disconnected from my home Wi-Fi.
While doing some digging, I discovered that every time the app attempts to update a sensor, it receives a 405 error code along with the error message "405: Method Not Allowed". As far as I can tell, this issue appeared after updating the android app from version 2025.12.2-full to 2025.12.3-full.
**Companion App Logs:**
--------- beginning of system
12-24 00:15:26.817 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:15:26.843 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:15:26.875 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:15:56.249 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:15:57.896 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:16:42.744 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:16:42.745 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:16:43.572 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:16:59.367 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:16:59.387 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:16:59.445 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:17:01.841 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:17:01.871 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:17:02.687 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:05.916 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:05.925 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:05.985 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:17.425 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:17.455 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:18.234 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:20.930 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:20.939 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:20.973 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:22.770 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:22.805 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
12-24 00:19:23.609 11512 11512 W VRI[WebViewActivity]: handleResized abandoned!
--------- beginning of main
12-24 00:20:37.911 11512 15693 D OplusScrollToTopManager: io.homeassistant.companion.android/io.homeassistant.companion.android.webview.WebViewActivity,This com.android.internal.policy.DecorView{30e8ef4 V.E...... R....... 0,0-1440,3216 aid=14 alpha=1.0 viewInfo = }[WebViewActivity] change focus to false
12-24 00:20:38.177 11512 11512 D callGcSupression: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[])' on a null object reference
12-24 00:20:38.177 11512 11512 D ScrollOptim [SceneManager]: updateCurrentActivity: mCurrentActivityName=null, isOptEnable=true, isAnimAheadEnable=true, isFrameInsertEnable=true, InsertNum=1, isEnabledForScrollChanged=false
12-24 00:20:38.190 11512 11512 D IntegrationRepositoryImpl: setAppActive(): false
12-24 00:20:38.208 11512 20530 D VRI[WebViewActivity]: dispatchAppVisibility visible:false
12-24 00:20:38.212 11512 11512 D SensorReceiverBase: Received intent: io.homeassistant.companion.android.UPDATE_SENSORS
12-24 00:20:38.213 11512 11512 D VRI[WebViewActivity]: visibilityChanged oldVisibility=true newVisibility=false
12-24 00:20:38.239 11512 11512 D HWUI : RenderProxy::destroy: this=0xb400007857e8e200, mContext=0xb4000077c04d63c0
12-24 00:20:38.239 11512 15619 D HWUI : SkiaOpenGLPipeline::setSurface: this=0xb40000787b52b080, surface=NULL
12-24 00:20:38.241 11512 15619 D BufferQueueProducer: [VRI[WebViewActivity]#72(BLAST Consumer)72](id:2cf800000064,api:1,p:11512,c:11512) disconnect: api 1
12-24 00:20:38.243 11512 11512 D ViewRootImplExtImpl: wrapConfigInfoIntoFlags rotation=0, smallestScreenWidthDp=411, relayoutAsync=false, flags=0, newFlags=26935296, residentWS=false, title=io.homeassistant.companion.android/io.homeassistant.companion.android.webview.WebViewActivity
12-24 00:20:38.256 11512 11512 D VRI[WebViewActivity]: relayoutWindow result, sizeChanged:false, surfaceControlChanged:true, transformHintChanged:false, mSurfaceSize:Point(1440, 3216), mLastSurfaceSize:Point(1440, 3216), mWidth:1440, mHeight:3216, requestedWidth:1440, requestedHeight:3216, transformHint:0, installOrientation:0, displayRotation:0, isSurfaceValid:false, attr.flag:-2122251904, tmpFrames:ClientWindowFrames{frame=[0,0][1440,3216] display=[0,0][1440,3216] parentFrame=[0,0][0,0]}, relayoutAsync:false, mSyncSeqId:0
12-24 00:20:38.257 11512 11512 D BLASTBufferQueue: [VRI[WebViewActivity]#72](f:0,a:1) destructor()
12-24 00:20:38.257 11512 11512 D BufferQueueConsumer: [VRI[WebViewActivity]#72(BLAST Consumer)72](id:2cf800000064,api:0,p:-1,c:11512) disconnect
12-24 00:20:38.264 11512 11512 D callGcSupression: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[])' on a null object reference
12-24 00:20:38.268 11512 11512 W WindowOnBackDispatcher: sendCancelIfRunning: isInProgress=false callback=androidx.navigationevent.OnBackInvokedInput$createOnBackAnimationCallback$1@10081a3
12-24 00:20:38.268 11512 11512 D VRI[WebViewActivity]: setWindowStopped stopped:true
12-24 00:20:38.271 11512 11512 V AutofillManager: updateSessionLocked(): id=null, bounds=null, value=null, action=5, flags=0
12-24 00:20:38.331 11512 11512 D ViewRootImplExtImpl: wrapConfigInfoIntoFlags rotation=0, smallestScreenWidthDp=411, relayoutAsync=false, flags=0, newFlags=26935296, residentWS=false, title=io.homeassistant.companion.android/io.homeassistant.companion.android.webview.WebViewActivity
12-24 00:20:38.337 11512 11512 D VRI[WebViewActivity]: relayoutWindow result, sizeChanged:false, surfaceControlChanged:true, transformHintChanged:false, mSurfaceSize:Point(1440, 3216), mLastSurfaceSize:Point(1440, 3216), mWidth:1440, mHeight:3216, requestedWidth:1440, requestedHeight:3216, transformHint:0, installOrientation:0, displayRotation:0, isSurfaceValid:false, attr.flag:-2122251904, tmpFrames:ClientWindowFrames{frame=[0,0][1440,3216] display=[0,0][1440,3216] parentFrame=[0,0][0,0]}, relayoutAsync:false, mSyncSeqId:0
12-24 00:20:38.634 11512 22191 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:20:38.641 11512 22191 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:20:38.677 11512 22185 D ForegroundServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-24 00:20:38.731 11512 11512 D LocationSensorManager: Not requesting accurate location, last accurate location was too recent
12-24 00:20:38.750 11512 10289 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: Error while getting core config to sync sensor status aborting
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: io.homeassistant.companion.android.common.data.integration.IntegrationException: retrofit2.HttpException: HTTP 405 Method Not Allowed
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.tryOnUrls(IntegrationRepositoryImpl.kt:691)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.access$tryOnUrls(IntegrationRepositoryImpl.kt:70)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$tryOnUrls$1.invokeSuspend(Unknown Source:15)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:34)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:98)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.internal.LimitedDispatcher$Worker.run(LimitedDispatcher.kt:124)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.scheduling.TaskImpl.run(Tasks.kt:89)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:586)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:820)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:717)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:704)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: Caused by: retrofit2.HttpException: HTTP 405 Method Not Allowed
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:164)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:576)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1154)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:652)
12-24 00:20:38.952 11512 10289 E SensorReceiverBase: at java.lang.Thread.run(Thread.java:1563)
12-24 00:20:38.953 11512 10289 I SensorReceiverBase: Sensor updates and sync completed
12-24 00:20:43.303 11512 11512 D LocationSensorManager$requestSingleAccurateLocation: Got single accurate location update: Location[fused 55.******,11.****** hAcc=3.79 et=+11d9h43m17s615ms alt=46.89999771118164 vAcc=1.0944078 vel=0.0 sAcc=0.24433435]
12-24 00:20:43.303 11512 11512 D LocationSensorManager$requestSingleAccurateLocation: Location accurate enough, all done with high accuracy.
12-24 00:20:43.304 11512 22185 D LocationSensorManager: Last Location:
12-24 00:20:43.304 11512 22185 D LocationSensorManager: Coords:(55.*******, 11.*******)
12-24 00:20:43.304 11512 22185 D LocationSensorManager: Accuracy: 3.79
12-24 00:20:43.304 11512 22185 D LocationSensorManager: Bearing: 0.0
12-24 00:20:43.306 11512 22185 D LocationSensorManager: Begin evaluating if location update should be skipped
12-24 00:20:43.306 11512 22185 D LocationSensorManager: Received location that is 59 milliseconds old, 1766532043246 compared to 1766532043305 with source fused
12-24 00:20:43.309 11512 22185 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: Could not update location for 1.
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: io.homeassistant.companion.android.common.data.integration.IntegrationException: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling webhook, httpCode: 405, errorBody: 405: Method Not Allowed
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.tryOnUrls(IntegrationRepositoryImpl.kt:691)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.access$tryOnUrls(IntegrationRepositoryImpl.kt:70)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$tryOnUrls$1.invokeSuspend(Unknown Source:15)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:34)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:100)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.internal.LimitedDispatcher$Worker.run(LimitedDispatcher.kt:124)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.scheduling.TaskImpl.run(Tasks.kt:89)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:586)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:820)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:717)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:704)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: Caused by: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling webhook, httpCode: 405, errorBody: 405: Method Not Allowed
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$callWebhookOnUrls$response$1.invokeSuspend(IntegrationRepositoryImpl.kt:657)
12-24 00:20:43.432 11512 22185 E LocationSensorManager$sendLocationUpdate: ... 8 more
12-24 00:21:00.512 11512 11512 D SensorReceiverBase: Received intent: android.intent.action.TIME_TICK
12-24 00:21:00.728 11512 22185 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:21:00.734 11512 22185 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:21:00.779 11512 22185 D ForegroundServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-24 00:21:00.950 11512 11512 D LocationSensorManager: Received location update.
12-24 00:21:00.981 11512 22191 D ServerConnectionStateProviderImpl: usesInternalSsid is: false, usesWifi is: false
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: Error while getting core config to sync sensor status aborting
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: io.homeassistant.companion.android.common.data.integration.IntegrationException: retrofit2.HttpException: HTTP 405 Method Not Allowed
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.tryOnUrls(IntegrationRepositoryImpl.kt:691)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.access$tryOnUrls(IntegrationRepositoryImpl.kt:70)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$tryOnUrls$1.invokeSuspend(Unknown Source:15)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:34)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:98)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.internal.LimitedDispatcher$Worker.run(LimitedDispatcher.kt:124)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.scheduling.TaskImpl.run(Tasks.kt:89)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:586)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:820)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:717)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:704)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: Caused by: retrofit2.HttpException: HTTP 405 Method Not Allowed
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:164)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:576)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1154)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:652)
12-24 00:21:01.106 11512 22191 E SensorReceiverBase: at java.lang.Thread.run(Thread.java:1563)
12-24 00:21:01.107 11512 22191 I SensorReceiverBase: Sensor updates and sync completed
**Screenshot or video of problem:**
**Additional information:**
