My Zigbee and Bluetooth environment does not always run smoothly. I would therefore like to monitor them. How do I do this? I retrieve all entities from the corresponding integrations that have the value ‘unavailable’ and retrieve the device for the entity. I then count the devices. This is then list no. 1 If the total is greater than 0, I want to be notified on the mobile phone.
The challenge here is that I have lights that can be controlled via Zigbee - but don’t have to be. The lights also each have a normal switch. I therefore have to remove all the lights from the monitoring. This means that if a light is ‘unavailable’, it doesn’t matter. To do this, I create a list of all the lights. This is list 2.
I have created a template sensor that I want to use later in automations. This is the code I built for it. Basically, it checks whether there are any devices left after comparing list 1 with list 2. It then counts them and the result of the count is the state of the sensor.
- sensor:
- name: "OfflineDevices"
unique_id: "sensor.offline_devices"
icon: mdi:CreditCardWirelessOff
state: >
{% set light_entities = states.light | list %}
{% set device_names = namespace(my_lights=[]) %}
{% for light in light_entities %}
{% set device = light.attributes.friendly_name | string %}
{% set device_names.my_lights = device_names.my_lights + [device] %}
{% endfor %}
{% set unique_device_lights = device_names.my_lights | unique | list %}
{% set result=namespace(offline_devices=[]) %}
{% set integrations=['mqtt', 'zwave_js', 'zha', 'homekit_controller', 'govee_ble', 'switchbot'] %}
{% for integration in integrations %}
{% for device in integration_entities(integration) | map('device_id') | sort | unique | list %}
{% for entity in device_entities(device) %}
{% if "unavailable" in expand(entity)|string %}
{% set offline_name = iif(device_attr(device, "name_by_user"), device_attr(device, "name_by_user"), "ERROR", device_attr(device, "name")) %}
{% if offline_name not in unique_device_lights %}
{% set result.offline_devices = result.offline_devices + [offline_name] %}
{% endif %}
{% endif %}
{% endfor %}
{% endfor %}
{% endfor %}
{{ result.offline_devices | unique | list | length }}
attributes:
list_of_offline_devices: >
{% endfor %}
{% endif %}
{% endif %}
{% endfor %}
{% endfor %}
{% endfor %}
{{ result.offline_devices | sort | unique | join(', ') }}
I’m a beginner, so I don’t think the code is very good. But at the moment I can’t do any better. I have a few problems now.
1: I think HA has slowed down significantly since I enabled the sensor.
2: I keep getting the error
WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'friendly_name' when rendering '{% set light_entities = states.light | list %} {% set device_names = namespace(my_lights=[]) %} {% for light in light_entities %}
{% set device = light.attributes.friendly_name | string %}...
in the log and the log is full.
Is it possible to optimise the code or build it differently so that the queries don’t run all the time?
How do I get rid of the error? How can I find out which device does not have a ‘friendly_name’? The name is essential for the comparison between the two lists.
