Problems with Conbee in Deconz Integration
I have installed conbee and deconz software on win 10.
Software finds devices and webapp opens.
But in Deconzaddon can#t connect - because of bad gateway
I do not know what to fill in configuration for host deconzapi … deconzwebfrontend … and deconzwebsocket … to connect successfully
Please help
ogiot
Is the ConBee still plugged in your windows machine and you want to connect HA to it or did you move the ConBee to the machine running HA and you can’r get it to work?
the stick is in the machine. I want it connected to hass.
Deconz (App) - in windows - has the stick detected already. The stick seems o.k.
But in Hass I dont get it going.
Hass says - bad gateway. I think the configuration ist not o.k.
Let’s break it down so we are clear…
You have DeConz running in Windows and you can see the ConBee stick which is plugged into the Windows machine. (Correct or not correct?)
You WANT to now transfer the stick to your HA Install. (Correct or not correct?)
Some info missing from here:
  1. Is Home Assistant on the same hardware as Windows or a different platform?
  2. Are you running the HA DeConz integration?
  3. Did you follow the instructions in the HA integration to set up the ConBee stick in the configuration section of the HA integration?
Fill in the gaps and we can hopefully get you running.
In which machine is the stick?
Did you follow the steps in the docs for the add-on? https://github.com/home-assistant/addons/blob/4707be688c419caf5d3f583788d9de23d30d1b01/deconz/DOCS.md
