I’ve successfully setup Home Assistant with the raspberry pi image. However when i try to configure it, and then restart it i lose it, and have to flash it again. It is kinda annoying. Not sure what i do wrong.
Also i would much rather run home assistant in a virtual machine, but I’ve been unable to make home assistant run on anything besides a raspberry pi.
Are there anyone out there that might be able to help me? I’m really lost, and not sure what to do
Also if someone could say how i should categorize and tag this post, I would be happy to do so.
This is certainly possible. I do it for running my test configuration, but there is no reason why it couldn’t run permanently. The instructions for creating and running in a virtual environment should work fine, no matter what linux distribution you use.
There are some more specific instructions for other distros, if you are interested
Okay. Then I think I’ll just give up on running it on a raspberry pi… I did Google the error, many have the problem. Properly some config file. But the command line is odd in hass.io …
Thanks. It worked, but still didn’t help much. Not sure where the files I need are even located.
Anyways. I’ve given up on Hassio. It prevents me from doing what i want, or makes it harder/guides to another approach at the problem that I would like to do.
The guides @gpbenton linked to worked great. I’m up and running now, making automations and having fun.
Thanks for your help!. It turned out hassio wasn’t suited for me
