Because I desperately want a Grafana dashboard in Home-assistant I decided to install Home-assistant in docker container (on a ssd mounted to Raspberry)
Most things work fine after restoring config.
However: my Rflink doesn’t seem to connect to Home assistant.
I my config I have
rflink:
port: /dev/ttyACM0
port number was checked with ls /dev/tty*
I thought this was the command to let USB-devices connect :
docker run -ti --privileged ubuntu bash
but still no luck
What do I have to change ?
