Hello everyone!
I’m new to HA and i like it very much!!! Don’t have any experience with coding and stuff, but a lot is very good to follow. Have already 20+ automations implemented. And i love it!
ow I’m working on a new one: automation with my curtains from Switch-Bot.
The problem is that i cant fire an event for the curtains after a trigger. The curtains wont do anything, but i can acces it manualy though through the panel.
Steps I’ve done to get the device in HA:
1. I edit /config/configuration.yaml and add this:
rest_command:
switchbot_device_command:
url: 'https://api.switch-bot.com/v1.0/devices/{{ deviceId }}/commands'
method: post
content_type: 'application/json'
headers:
Authorization: !secret switchbot_api
payload: '{"command": "{{ command }}","parameter": "{{ parameter }}"}'
- platform: rest
name: 'Woonkamer Gordijnen'
resource: !secret switchbot_woonkamer_status_url
method: GET
scan_interval: 600
headers:
Content-Type: 'application/json'
value_template: '{{ value_json.body.slidePosition }}'
json_attributes_path: "$.body"
json_attributes:
- deviceId
- deviceType
- hubDeviceId
- calibrate
- group
- moving
- slidePosition
cover:
covers:
bedroom_curtains:
device_class: curtain
friendly_name: "Woonkamer Gordijnen"
position_template: "{{ states('sensor.bedroom_curtain_position') }}"
open_cover:
service: rest_command.switchbot_device_command
deviceId: !secret switchbot_woonkamer_deviceId
command: "turnOn"
close_cover:
command: "turnOff"
stop_cover:
command: "turnOff"
set_cover_position:
command: "setPosition"
parameter: "0,ff,{{position}}"
2 I added /config/secrets.yaml and add this:
switchbot_api: "*my api of the device ;)*"
#Switchbot-Gordijn Woonkamer
switchbot_woonkamer_status_url: "https://api.switch-bot.com/v1.0/devices/E858B439BFA2/status"
switchbot_woonkamer_deviceId: "E858B439BFA2"
Than the identity is visible:
And i can change it positions, so far it works:
placed an images, but because i’m a new user cant place more that 1 image
Than i try to change the position of this curtain by the following code:
service: cover.set_cover_position
position: 50
entity-id: cover.bedroom_curtains
But nothing happens, even when i run it manualy it says: succesfully excuted. Also can’t nothing find in the log that points to this.
What can i do to get this work? What do i do wrong in this case, can’t figure it out.
I’m very curious to you guys reactions! Thank you for your time to dive into this problem!
Greetz!
Marwin
