After updating to 2025.1 I unfortunately have a problem with the custom integration for my WAREMA blinds.
Despite updating I haven’t changed anything but the entities are no logger working.
‘Check configuration’ is showing me the following:
Configuration warnings
Platform error 'cover' from integration 'warema_wms_webcontrol' - cannot import name 'DEVICE_CLASS_SHADE' from 'homeassistant.components.cover' (/usr/src/homeassistant/homeassistant/components/cover/__init__.py)
And I have the following log entry:
Logger: homeassistant.config
Source: config.py:1055
First occurred: January 7, 2025 at 14:43:54 (1 occurrences)
Last logged: January 7, 2025 at 14:43:54
Platform error: cover - cannot import name 'DEVICE_CLASS_SHADE' from 'homeassistant.components.cover' (/usr/src/homeassistant/homeassistant/components/cover/__init__.py)
File "/usr/src/homeassistant/homeassistant/config.py", line 1055, in _async_load_and_validate_platform_integration
platform = await p_integration.integration.async_get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1108, in async_get_platform
platforms = await self.async_get_platforms((platform_name,))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1185, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1173, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1098, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1272, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1304, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/warema_wms_webcontrol/cover.py", line 7, in <module>
from homeassistant.components.cover import (
CoverEntity, DEVICE_CLASS_SHADE, SUPPORT_OPEN, SUPPORT_CLOSE,
SUPPORT_SET_POSITION, ATTR_POSITION, PLATFORM_SCHEMA)
ImportError: cannot import name 'DEVICE_CLASS_SHADE' from 'homeassistant.components.cover' (/usr/src/homeassistant/homeassistant/components/cover/__init__.py)
I appreciate any help as it sucks to not be able to use the blinds via HA anymore. Updating to 2025.1.1 didn’t help.
