Problems with Deconz after moving to nuc
Hi there, i used to have home assistant installed on a Rpi3b+ and moved on to a nuc…now i got deconz working on the pi without any problems, but now i got this: the sensors show up, but none of them work…
any help, please!
thanks!
[services.d] done.
starting version 237
[12:36:56] INFO: Waiting for device…
[12:36:56] INFO: Starting VNC server…
[12:36:59] INFO: Starting the deCONZ gateway…
libpng warning: iCCP: known incorrect sRGB profile
12:37:00:147 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
12:37:00:159 CTRL. 3.22.012:37:00:225 COM: --dev: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1997537-if00 (RaspBee)
12:37:00:225 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
12:37:00:304 parent process bash
12:37:00:304 gw run mode: docker/hassio
12:37:00:304 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
12:37:00:305 DB sqlite version 3.22.0
12:37:00:305 DB PRAGMA page_count: 30
12:37:00:305 DB PRAGMA page_size: 4096
12:37:00:305 DB PRAGMA freelist_count: 0
12:37:00:305 DB file size 122880 bytes, free pages 0
12:37:00:306 DB PRAGMA user_version: 6
12:37:00:306 DB cleanup
12:37:00:306 DB create temporary views
12:37:00:310 don’t close database yet, keep open for 900 seconds
12:37:00:311 started websocket server at port 8081
12:37:00:313 found node plugin: libde_rest_plugin.so - REST API Plugin
12:37:00:314 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
[12:37:00] INFO: Starting Nginx…
[12:37:00] INFO: Running Home Assistant discovery task…
2020/03/20 12:37:00 [notice] 612#612: using the “epoll” event method
2020/03/20 12:37:00 [notice] 612#612: nginx/1.14.0 (Ubuntu)
2020/03/20 12:37:00 [notice] 612#612: OS: Linux 4.15.0-88-generic
2020/03/20 12:37:00 [notice] 612#612: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2020/03/20 12:37:00 [notice] 612#612: start worker processes
2020/03/20 12:37:00 [notice] 612#612: start worker process 619
[12:37:00] INFO: Running the deCONZ OTA updater…
[12:37:00] INFO: Running the IKEA OTA updater…
[12:37:00] INFO: Running the LEDVANCE/OSRAM OTA updater…
[12:37:00] INFO: deCONZ is set up and running!
12:37:02:482 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
12:37:02:506 COM: --dev: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1997537-if00 (RaspBee)
12:37:06:302 Announced to internet http://dresden-light.appspot.com/discover
12:37:07:847 New websocket 172.30.32.1:41538 (state: 3)
[12:37:10] INFO: Successfully send discovery information to Home Assistant.
12:37:12:765 COM: --dev: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1997537-if00 (RaspBee)
12:37:12:792 Device firmware version 0x264A0700
12:37:12:797 unlocked max nodes: 200
12:37:12:867 Device protocol version: 0x010B
12:37:12:874 new node - ext: 0x00212effff048978, nwk: 0x0000
12:37:12:898 SensorNode 3 set node 0x00158d00034ce330
12:37:12:898 SensorNode 4 set node 0x00158d00034ce330
12:37:12:915 SensorNode 7 set node 0x00158d0003536199
12:37:12:915 SensorNode 8 set node 0x00158d0003536199
12:37:12:938 don’t close database yet, keep open for 900 seconds
12:37:12:938 SensorNode 2 set node 0x00158d00024605ed
12:37:12:939 don’t close database yet, keep open for 900 seconds
12:37:12:955 SensorNode 5 set node 0x00158d00035fecab
12:37:12:955 SensorNode 6 set node 0x00158d00035fecab
12:37:13:017 Current channel 15
12:37:13:033 CTRL ANT_CTRL 0x03
12:37:13:058 Device protocol version: 0x010B
12:37:13:105 Current channel 15
12:37:13:121 CTRL ANT_CTRL 0x03
12:37:14:043 don’t close database yet, keep open for 900 seconds
12:37:14:043 LightNode 1: Configuration tool 1 added
12:37:15:067 CTRL restore cached node 0x00158d00035fecab
12:37:15:067 Node zombie state changed 0x00158d00035fecab
12:37:15:068 new node - ext: 0x00158d00035fecab, nwk: 0x6371
12:37:15:768 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26490700.bin.GCF
12:37:15:768 GW firmware version: 0x264a0700
12:37:15:768 GW firmware version is up to date: 0x264a0700
12:37:24:906 APS-DATA.indication from unknown node 0x00158D00024605ED
12:37:24:906 no button map for: lumi.sensor_magnet ep: 0x01 cl: 0x0006 cmd: 0x0A pl[0]: 000
12:37:24:907 ZCL attribute report 0x00158D00024605ED for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
12:37:28:089 APS-DATA.indication from unknown node 0x00158D00024605ED
12:37:28:089 no button map for: lumi.sensor_magnet ep: 0x01 cl: 0x0006 cmd: 0x0A pl[0]: 000
12:37:28:089 ZCL attribute report 0x00158D00024605ED for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
12:37:59:748 Current channel 15
12:37:59:756 Device TTL 2915 s flags: 0x7
12:38:57:269 no button map for: lumi.sensor_ht ep: 0x01 cl: 0x0402 cmd: 0x0A pl[0]: 000
12:38:57:269 ZCL attribute report 0x00158D0003536199 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
12:38:57:278 no button map for: lumi.sensor_ht ep: 0x01 cl: 0x0405 cmd: 0x0A pl[0]: 000
12:38:57:278 ZCL attribute report 0x00158D0003536199 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
12:38:59:751 Current channel 15
12:38:59:759 Device TTL 2855 s flags: 0x7
12:39:59:751 Current channel 15
12:39:59:759 Device TTL 2795 s flags: 0x7
12:40:20:619 APS-DATA.indication from unknown node 0x00158D00024605ED
12:40:20:619 no button map for: lumi.sensor_magnet ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 002
12:40:20:619 ZCL attribute report 0x00158D00024605ED for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x1234
12:40:20:619 0x00158D00024605ED extract Xiaomi special attribute 0xFF02
12:40:20:619 64 on/off 0
12:40:20:619 01 battery 2955 (0x0B8B)
12:40:20:619 03 unsupported index (data type 0x21)
12:40:20:619 04 unsupported index (data type 0x24)
12:40:20:619 05 unsupported index (data type 0x21)
12:40:20:619 06 unsupported index (data type 0x20)
12:40:24:187 CTRL restore cached node 0x00158d00024605ed
12:40:24:187 Node zombie state changed 0x00158d00024605ed
