Problems with deep sleep on a Xiao ESP32C6
Hi, I try to create a Zigbee door sensor with an additional lock sensor with a XIAO ESP32C6 board. I have following Yaml code;
# Board: Seeed Studio XIAO ESP32C6 (Seeed Studio)
# Definition: definitions/boards/seeed_xiao_esp32c6/manifest.yaml
esphome:
  friendly_name: washok door and lock sensor
  area: Kitchen
esp32:
  variant: esp32c6
  flash_size: 4MB
  framework:
    type: esp-idf
output: #to select the external antenna
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO15
deep_sleep:
  sleep_duration: 10min
  run_duration:
    default: 40s # Royaal venster van 20 seconden bij boot voor stabiele Zigbee-afhandeling
  esp32_ext1_wakeup:
    mode: ANY_LOW
    pins:
      - pin:
          number: GPIO1
          allow_other_uses: true
          mode:
            pullup: true
            input: true
          inverted: true
      - pin:
          number: GPIO2
          mode:
            input: true
            pullup: true
          inverted: true
zigbee:
  power_source: BATTERY
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO1 #D1
      mode:
        input: true
        pullup: true
      inverted: true
    filters: #debouncing value 10ms
      - delayed_on: 10ms
  - platform: gpio
    pin:
      number: GPIO2  #D2
      mode:
        input: true
        pullup: true
      inverted: true
      - delayed_on: 10ms
The problem is that without the Deep sleep block everything works fine. only my battery is depleted very fast. If i add this deep sleep block the board becomes unresponsive. is there somebody who knows how to configure this?
There is an issue with esphome deepsleep and the zigbee stack, use standard arduino code to have both. I can provide a code example if you can’t find any.
