Problems with docker add ons in raspberry 4
Recently I installed Home Assistant in a Raspberry 4 (with Open Media Vault as operating system) following this guide:
All is working fine, except when I restart the system (reboot command), then all the addons containers dissapear!! :frowning:
The homeassistant container does not dissapear but I have to start it manually (this is a minor issue)…
Anyone knows the solution to this problem? I have to reinstall the addons every time I reboot the system…
Thanks!!
Finally I resolved the issue executing this command from the terminal:
ha supervisor repair
Once executed reboot the server.
