Hello everybody,
So I know this is not the first topic on duckdns and lets encrypt, but the existing topics are not working out for me.
I had a secure remote access up and running on hassbian. I used this very good and clear guide: https://www.home-assistant.io/docs/ecosystem/certificates/lets_encrypt. But after 8 days it suddenly stopped working. I could not reach my home assistant anymore, it gave the error that there could not be made a secure connection to the server. I tried to renew my lets encrypt certificate, but it had not expired and the new certificated did not change anything.
I was not able to resolve the problem, so a bit frustraded I decided to setup Hass.io. I installed the image and did a migration of my old hassbian setup. After I tested that everything was working a installed and setup the duckdns add-on (also added the lines under http: in the config file).
After starting the add-on I get the following errors in the log (i xxx’ed a few lines which I believe contain some private information):
# INFO: Using main config file /data/workdir/config
+ Account already registered!
Sat Sep 15 19:35:12 CEST 2018: OK
XXXXXXX
NOCHANGE
Processing XXXX
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ ERROR: An error occurred while sending post-request to https://acme-v02.api.letsencrypt.org/acme/new-order (Status 400)
Details:
HTTP/1.1 100 Continue
Expires: Sat, 15 Sep 2018 17:35:39 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
HTTP/1.1 400 Bad Request
Server: nginx
Content-Type: application/problem+json
Content-Length: 149
Boulder-Requester: XXXXX
Replay-Nonce: XXXXXXX
Expires: Sat, 15 Sep 2018 17:35:40 GMT
Pragma: no-cache
Date: Sat, 15 Sep 2018 17:35:40 GMT
Connection: close
"type": "urn:ietf:params:acme:error:malformed",
"detail": "Error creating new order :: DNS name does not have enough labels",
"status": 400
So it looks like its not possible to make a certificate, but I don’t understand why? I have no idea how to troubleshoot this. Really hope someone can help me out!
Best regards,
Xander
