Hi There!
First post! Been enjoying configuring and using Home Assistant very much.
But… i need some help!
I’ve been busy trying to hookup my “Slimme Meter” to and ESP8266 so i can read data via MQTT.
Using the Home Assistant website i found the Fliphess esp8266_p1meter code. I tried to validate it using Arduino (which i use to flash my ESP’s) but ran into a problem.
I get an error message saying:
no matching function for call to ‘SoftwareSerial::SoftwareSerial(int, int, bool, int)’
I saw the code at GitHub was around 2 years old, so i guess it’s calling some deprecated stuff. But google didn’t really help. A lot of different solutions with all their own problems. So, i’m hoping one of you knows what i need to do!
I’ll be adding the full code down here.
I have installed the ESP framework, and all libraries seem to be present.
My “Slimme meter” is an Kamstrup 162 so i changed to Baudrate (when compared to original code).
#include <FS.h>
#include <EEPROM.h>
#include <DNSServer.h>
#include <ESP8266WiFi.h>
#include <Ticker.h>
#include <WiFiManager.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <PubSubClient.h>
#include <SoftwareSerial.h>
// * Baud rate for both hardware and software serial
#define BAUD_RATE 9600
// * P1 Meter RX pin
#define P1_SERIAL_RX 13
// * Max telegram length
#define P1_MAXLINELENGTH 64
// * The hostname of our little creature
#define HOSTNAME "p1meter"
// * The password used for OTA
#define OTA_PASSWORD "admin"
// * Wifi timeout in milliseconds
#define WIFI_TIMEOUT 30000
// * MQTT network settings
#define MQTT_MAX_RECONNECT_TRIES 10
// * MQTT root topic
#define MQTT_ROOT_TOPIC "sensors/power/p1meter"
// * MQTT Last reconnection counter
long LAST_RECONNECT_ATTEMPT = 0;
// * To be filled with EEPROM data
char MQTT_HOST[64] = "";
char MQTT_PORT[6] = "";
char MQTT_USER[32] = "";
char MQTT_PASS[32] = "";
// * Set to store received telegram
char telegram[P1_MAXLINELENGTH];
// * Set to store the data values read
long CONSUMPTION_LOW_TARIF;
long CONSUMPTION_HIGH_TARIF;
long ACTUAL_CONSUMPTION;
long INSTANT_POWER_CURRENT;
long INSTANT_POWER_USAGE;
long GAS_METER_M3;
// Set to store data counters read
long ACTUAL_TARIF;
long SHORT_POWER_OUTAGES;
long LONG_POWER_OUTAGES;
long SHORT_POWER_DROPS;
long SHORT_POWER_PEAKS;
// * Set during CRC checking
unsigned int currentCRC = 0;
// * Initiate led blinker library
Ticker ticker;
// * Initiate WIFI client
WiFiClient espClient;
// * Initiate MQTT client
PubSubClient mqtt_client(espClient);
// * Initiate Software Serial
SoftwareSerial p1_serial(P1_SERIAL_RX, -1, true, P1_MAXLINELENGTH); // (RX, TX. inverted, buffer)
// * WIFI *
// * Gets called when WiFiManager enters configuration mode
void configModeCallback(WiFiManager *myWiFiManager)
Serial.println(F("Entered config mode"));
Serial.println(WiFi.softAPIP());
// * If you used auto generated SSID, print it
Serial.println(myWiFiManager->getConfigPortalSSID());
// * Entered config mode, make led toggle faster
ticker.attach(0.2, tick);
// * Ticker (System LED Blinker) *
// * Blink on-board Led
void tick()
// * Toggle state
int state = digitalRead(LED_BUILTIN); // * Get the current state of GPIO1 pin
digitalWrite(LED_BUILTIN, !state); // * Set pin to the opposite state
// * MQTT *
// * Send a message to a broker topic
void send_mqtt_message(const char *topic, char *payload)
Serial.printf("MQTT Outgoing on %s: ", topic);
Serial.println(payload);
bool result = mqtt_client.publish(topic, payload, false);
if (!result)
Serial.printf("MQTT publish to topic %s failed\n", topic);
// * Reconnect to MQTT server and subscribe to in and out topics
bool mqtt_reconnect()
// * Loop until we're reconnected
int MQTT_RECONNECT_RETRIES = 0;
while (!mqtt_client.connected() && MQTT_RECONNECT_RETRIES < MQTT_MAX_RECONNECT_TRIES)
MQTT_RECONNECT_RETRIES++;
Serial.printf("MQTT connection attempt %d / %d ...\n", MQTT_RECONNECT_RETRIES, MQTT_MAX_RECONNECT_TRIES);
// * Attempt to connect
if (mqtt_client.connect(HOSTNAME, MQTT_USER, MQTT_PASS))
Serial.println(F("MQTT connected!"));
// * Once connected, publish an announcement...
char *message = new char[16 + strlen(HOSTNAME) + 1];
strcpy(message, "p1 meter alive: ");
strcat(message, HOSTNAME);
mqtt_client.publish("hass/status", message);
Serial.printf("MQTT root topic: %s\n", MQTT_ROOT_TOPIC);
else
Serial.print(F("MQTT Connection failed: rc="));
Serial.println(mqtt_client.state());
Serial.println(F(" Retrying in 5 seconds"));
Serial.println("");
// * Wait 5 seconds before retrying
delay(5000);
if (MQTT_RECONNECT_RETRIES >= MQTT_MAX_RECONNECT_TRIES)
Serial.printf("*** MQTT connection failed, giving up after %d tries ...\n", MQTT_RECONNECT_RETRIES);
return false;
return true;
void send_metric(String name, long metric)
Serial.print(F("Sending metric to broker: "));
Serial.print(name);
Serial.print(F("="));
Serial.println(metric);
char output[10];
ltoa(metric, output, sizeof(output));
String topic = String(MQTT_ROOT_TOPIC) + "/" + name;
send_mqtt_message(topic.c_str(), output);
void send_data_to_broker()
send_metric("consumption_low_tarif", CONSUMPTION_LOW_TARIF);
send_metric("consumption_high_tarif", CONSUMPTION_HIGH_TARIF);
send_metric("actual_consumption", ACTUAL_CONSUMPTION);
send_metric("instant_power_usage", INSTANT_POWER_USAGE);
send_metric("instant_power_current", INSTANT_POWER_CURRENT);
send_metric("gas_meter_m3", GAS_METER_M3);
send_metric("actual_tarif_group", ACTUAL_TARIF);
send_metric("short_power_outages", SHORT_POWER_OUTAGES);
send_metric("long_power_outages", LONG_POWER_OUTAGES);
send_metric("short_power_drops", SHORT_POWER_DROPS);
send_metric("short_power_peaks", SHORT_POWER_PEAKS);
// * P1 *
unsigned int CRC16(unsigned int crc, unsigned char *buf, int len)
for (int pos = 0; pos < len; pos++)
crc ^= (unsigned int)buf[pos]; // * XOR byte into least sig. byte of crc
// * Loop over each bit
for (int i = 8; i != 0; i--)
// * If the LSB is set
if ((crc & 0x0001) != 0)
// * Shift right and XOR 0xA001
crc >>= 1;
crc ^= 0xA001;
// * Else LSB is not set
else
// * Just shift right
crc >>= 1;
return crc;
bool isNumber(char *res, int len)
for (int i = 0; i < len; i++)
if (((res[i] < '0') || (res[i] > '9')) && (res[i] != '.' && res[i] != 0))
return false;
return true;
int FindCharInArrayRev(char array[], char c, int len)
for (int i = len - 1; i >= 0; i--)
if (array[i] == c)
return i;
return -1;
long getValue(char *buffer, int maxlen, char startchar, char endchar)
int s = FindCharInArrayRev(buffer, startchar, maxlen - 2);
int l = FindCharInArrayRev(buffer, endchar, maxlen - 2) - s - 1;
char res[16];
memset(res, 0, sizeof(res));
if (strncpy(res, buffer + s + 1, l))
if (endchar == '*')
if (isNumber(res, l))
// * Lazy convert float to long
return (1000 * atof(res));
else if (endchar == ')')
return atof(res);
return 0;
bool decode_telegram(int len)
int startChar = FindCharInArrayRev(telegram, '/', len);
int endChar = FindCharInArrayRev(telegram, '!', len);
bool validCRCFound = false;
for (int cnt = 0; cnt < len; cnt++)
Serial.print(telegram[cnt]);
if (startChar >= 0)
// * Start found. Reset CRC calculation
currentCRC = CRC16(0x0000,(unsigned char *) telegram+startChar, len-startChar);
else if (endChar >= 0)
// * Add to crc calc
currentCRC = CRC16(currentCRC,(unsigned char*)telegram+endChar, 1);
char messageCRC[5];
strncpy(messageCRC, telegram + endChar + 1, 4);
messageCRC[4] = 0; // * Thanks to HarmOtten (issue 5)
validCRCFound = (strtol(messageCRC, NULL, 16) == currentCRC);
if (validCRCFound)
Serial.println(F("CRC Valid!"));
else
Serial.println(F("CRC Invalid!"));
currentCRC = 0;
else
currentCRC = CRC16(currentCRC, (unsigned char*) telegram, len);
// 1-0:1.8.1(000992.992*kWh)
// 1-0:1.8.1 = Elektra verbruik laag tarief (DSMR v4.0)
if (strncmp(telegram, "1-0:1.8.1", strlen("1-0:1.8.1")) == 0)
CONSUMPTION_LOW_TARIF = getValue(telegram, len, '(', '*');
// 1-0:1.8.2(000560.157*kWh)
// 1-0:1.8.2 = Elektra verbruik hoog tarief (DSMR v4.0)
if (strncmp(telegram, "1-0:1.8.2", strlen("1-0:1.8.2")) == 0)
CONSUMPTION_HIGH_TARIF = getValue(telegram, len, '(', '*');
// 1-0:1.7.0(00.424*kW) Actueel verbruik
// 1-0:2.7.0(00.000*kW) Actuele teruglevering
// 1-0:1.7.x = Electricity consumption actual usage (DSMR v4.0)
if (strncmp(telegram, "1-0:1.7.0", strlen("1-0:1.7.0")) == 0)
ACTUAL_CONSUMPTION = getValue(telegram, len, '(', '*');
// 1-0:21.7.0(00.378*kW)
// 1-0:21.7.0 = Instantaan vermogen Elektriciteit levering
if (strncmp(telegram, "1-0:21.7.0", strlen("1-0:21.7.0")) == 0)
INSTANT_POWER_USAGE = getValue(telegram, len, '(', '*');
// 1-0:31.7.0(002*A)
// 1-0:31.7.0 = Instantane stroom Elektriciteit
if (strncmp(telegram, "1-0:31.7.0", strlen("1-0:31.7.0")) == 0)
INSTANT_POWER_CURRENT = getValue(telegram, len, '(', '*');
// 0-1:24.2.1(150531200000S)(00811.923*m3)
// 0-1:24.2.1 = Gas (DSMR v4.0) on Kaifa MA105 meter
if (strncmp(telegram, "0-1:24.2.1", strlen("0-1:24.2.1")) == 0)
GAS_METER_M3 = getValue(telegram, len, '(', '*');
// 0-0:96.14.0(0001)
// 0-0:96.14.0 = Actual Tarif
if (strncmp(telegram, "0-0:96.14.0", strlen("0-0:96.14.0")) == 0)
ACTUAL_TARIF = getValue(telegram, len, '(', ')');
// 0-0:96.7.21(00003)
// 0-0:96.7.21 = Aantal onderbrekingen Elektriciteit
if (strncmp(telegram, "0-0:96.7.21", strlen("0-0:96.7.21")) == 0)
SHORT_POWER_OUTAGES = getValue(telegram, len, '(', ')');
// 0-0:96.7.9(00001)
// 0-0:96.7.9 = Aantal lange onderbrekingen Elektriciteit
if (strncmp(telegram, "0-0:96.7.9", strlen("0-0:96.7.9")) == 0)
LONG_POWER_OUTAGES = getValue(telegram, len, '(', ')');
// 1-0:32.32.0(00000)
// 1-0:32.32.0 = Aantal korte spanningsdalingen Elektriciteit in fase 1
if (strncmp(telegram, "1-0:32.32.0", strlen("1-0:32.32.0")) == 0)
SHORT_POWER_DROPS = getValue(telegram, len, '(', ')');
// 1-0:32.36.0(00000)
// 1-0:32.36.0 = Aantal korte spanningsstijgingen Elektriciteit in fase 1
if (strncmp(telegram, "1-0:32.36.0", strlen("1-0:32.36.0")) == 0)
SHORT_POWER_PEAKS = getValue(telegram, len, '(', ')');
return validCRCFound;
void read_p1_serial()
if (p1_serial.available())
memset(telegram, 0, sizeof(telegram));
while (p1_serial.available())
ESP.wdtDisable();
int len = p1_serial.readBytesUntil('\n', telegram, P1_MAXLINELENGTH);
ESP.wdtEnable(1);
telegram[len] = '\n';
telegram[len + 1] = 0;
yield();
bool result = decode_telegram(len + 1);
if (result)
send_data_to_broker();
// * EEPROM helpers *
String read_eeprom(int offset, int len)
Serial.print(F("read_eeprom()"));
String res = "";
for (int i = 0; i < len; ++i)
res += char(EEPROM.read(i + offset));
return res;
void write_eeprom(int offset, int len, String value)
Serial.println(F("write_eeprom()"));
if ((unsigned)i < value.length())
EEPROM.write(i + offset, value[i]);
else
EEPROM.write(i + offset, 0);
// * Callback for saving WIFI config *
bool shouldSaveConfig = false;
// * Callback notifying us of the need to save config
void save_wifi_config_callback ()
Serial.println(F("Should save config"));
shouldSaveConfig = true;
// * Setup OTA *
void setup_ota()
Serial.println(F("Arduino OTA activated."));
// * Port defaults to 8266
ArduinoOTA.setPort(8266);
// * Set hostname for OTA
ArduinoOTA.setHostname(HOSTNAME);
ArduinoOTA.setPassword(OTA_PASSWORD);
ArduinoOTA.onStart([]()
Serial.println(F("Arduino OTA: Start"));
ArduinoOTA.onEnd([]()
Serial.println(F("Arduino OTA: End (Running reboot)"));
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total)
Serial.printf("Arduino OTA Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error)
Serial.printf("Arduino OTA Error[%u]: ", error);
if (error == OTA_AUTH_ERROR)
Serial.println(F("Arduino OTA: Auth Failed"));
else if (error == OTA_BEGIN_ERROR)
Serial.println(F("Arduino OTA: Begin Failed"));
else if (error == OTA_CONNECT_ERROR)
Serial.println(F("Arduino OTA: Connect Failed"));
else if (error == OTA_RECEIVE_ERROR)
Serial.println(F("Arduino OTA: Receive Failed"));
else if (error == OTA_END_ERROR)
Serial.println(F("Arduino OTA: End Failed"));
ArduinoOTA.begin();
Serial.println(F("Arduino OTA finished"));
// * Setup MDNS discovery service *
void setup_mdns()
Serial.println(F("Starting MDNS responder service"));
bool mdns_result = MDNS.begin(HOSTNAME);
if (mdns_result)
MDNS.addService("http", "tcp", 80);
// * Setup Main *
void setup()
// * Configure Serial and EEPROM
Serial.begin(BAUD_RATE);
EEPROM.begin(512);
// * Set led pin as output
pinMode(LED_BUILTIN, OUTPUT);
// * Start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
// * Start software serial for p1 meter
p1_serial.begin(BAUD_RATE);
// * Get MQTT Server settings
String settings_available = read_eeprom(134, 1);
if (settings_available == "1")
read_eeprom(0, 64).toCharArray(MQTT_HOST, 64); // * 0-63
read_eeprom(64, 6).toCharArray(MQTT_PORT, 6); // * 64-69
read_eeprom(70, 32).toCharArray(MQTT_USER, 32); // * 70-101
read_eeprom(102, 32).toCharArray(MQTT_PASS, 32); // * 102-133
WiFiManagerParameter CUSTOM_MQTT_HOST("host", "MQTT hostname", MQTT_HOST, 64);
WiFiManagerParameter CUSTOM_MQTT_PORT("port", "MQTT port", MQTT_PORT, 6);
WiFiManagerParameter CUSTOM_MQTT_USER("user", "MQTT user", MQTT_USER, 32);
WiFiManagerParameter CUSTOM_MQTT_PASS("pass", "MQTT pass", MQTT_PASS, 32);
// * WiFiManager local initialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
// * Reset settings - uncomment for testing
// wifiManager.resetSettings();
// * Set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode
wifiManager.setAPCallback(configModeCallback);
// * Set timeout
wifiManager.setConfigPortalTimeout(WIFI_TIMEOUT);
// * Set save config callback
wifiManager.setSaveConfigCallback(save_wifi_config_callback);
// * Add all your parameters here
wifiManager.addParameter(&CUSTOM_MQTT_HOST);
wifiManager.addParameter(&CUSTOM_MQTT_PORT);
wifiManager.addParameter(&CUSTOM_MQTT_USER);
wifiManager.addParameter(&CUSTOM_MQTT_PASS);
// * Fetches SSID and pass and tries to connect
// * Reset when no connection after 10 seconds
if (!wifiManager.autoConnect())
Serial.println(F("Failed to connect to WIFI and hit timeout"));
// * Reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(WIFI_TIMEOUT);
// * Read updated parameters
strcpy(MQTT_HOST, CUSTOM_MQTT_HOST.getValue());
strcpy(MQTT_PORT, CUSTOM_MQTT_PORT.getValue());
strcpy(MQTT_USER, CUSTOM_MQTT_USER.getValue());
strcpy(MQTT_PASS, CUSTOM_MQTT_PASS.getValue());
// * Save the custom parameters to FS
if (shouldSaveConfig)
Serial.println(F("Saving WiFiManager config"));
write_eeprom(0, 64, MQTT_HOST); // * 0-63
write_eeprom(64, 6, MQTT_PORT); // * 64-69
write_eeprom(70, 32, MQTT_USER); // * 70-101
write_eeprom(102, 32, MQTT_PASS); // * 102-133
write_eeprom(134, 1, "1"); // * 134 --> always "1"
EEPROM.commit();
// * If you get here you have connected to the WiFi
Serial.println(F("Connected to WIFI..."));
// * Keep LED on
ticker.detach();
digitalWrite(LED_BUILTIN, LOW);
// * Configure OTA
setup_ota();
// * Startup MDNS Service
setup_mdns();
// * Setup MQTT
Serial.printf("MQTT connecting to: %s:%s\n", MQTT_HOST, MQTT_PORT);
mqtt_client.setServer(MQTT_HOST, atoi(MQTT_PORT));
// * Loop *
void loop()
ArduinoOTA.handle();
if (!mqtt_client.connected())
long now = millis();
if (now - LAST_RECONNECT_ATTEMPT > 5000)
LAST_RECONNECT_ATTEMPT = now;
if (mqtt_reconnect())
else
mqtt_client.loop();
read_p1_serial();
