Hello everyone,
I have a problem with my D0 read head connected to an esp and integrated into hassio via esphome.
Yesterday there was a power failure for ~15min in the whole town. Since then the fuinction is limited. (I have now also updated esphome today in the hope that this will solve it - unfortunately without success)
What I don’t understand is that only the status “active power” is no longer transmitted.
The other values are transmitted:
Does anyone have any idea what I can do to solve the problem?
Unfortunately, the wallbox control is dependent on the active power status ;(
Log:
[19:51:16][D][d0:058]: OBIS info:
[19:51:16][D][d0:063]: 1-0:0.0.0*255 = 1EBZ0100791128
[19:51:16][D][d0:063]: 1-0:96.1.0*255 = 1EBZ0100791128
[19:51:16][D][d0:063]: 1-0:1.8.0*255 = 014967*kWh
[19:51:16][D][d0:063]: 1-0:1.8.1*255 = 000001*kWh
[19:51:16][D][d0:063]: 1-0:1.8.2*255 = 014966*kWh
[19:51:16][D][d0:063]: 1-0:2.8.0*255 = 053473*kWh
[19:51:16][D][d0:063]: 1-0:96.5.0*255 = 001C0104
[19:51:17][V][sensor:043]: 'Total energy': Received new state 14967.000000
[19:51:17][D][sensor:093]: 'Total energy': Sending state 14967.00000 kWh with 2 decimals of accuracy
[19:51:17][V][json:038]: Attempting to allocate 512 bytes for JSON serialization
[19:51:17][V][json:058]: Size after shrink 84 bytes
[19:51:17][V][text_sensor:013]: 'Total energy string': Received new state 014967*kWh
[19:51:17][D][text_sensor:064]: 'Total energy string': Sending state '014967*kWh'
[19:51:17][V][json:058]: Size after shrink 92 bytes
[19:51:17][V][sensor:043]: 'Energy Export': Received new state 53473.000000
[19:51:17][D][sensor:093]: 'Energy Export': Sending state 53473.00000 kWh with 2 decimals of accuracy
[19:51:17][D][d0:058]: OBIS info:
[19:51:17][D][d0:063]: 1-0:0.0.0*255 = 1EBZ0100791128
yaml.
external_components:
- source:
type: git
url: https://github.com/BMOD89/esphome_compontens
ref: main
components: [ d0 ]
esphome:
platform: ESP8266
board: nodemcuv2
includes:
- uart_read_line_sensor.h
# Enable logging
logger:
level: VERBOSE
baud_rate: 0
# Enable Home Assistant API
api:
ota:
password: "."
wifi:
networks:
- ssid: "xxx"
password: "xxx"
time:
- platform: homeassistant
captive_portal:
web_server:
port: 80
d0:
uart_id: uart_bus
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
data_bits: 7
parity: EVEN
stop_bits: 1
- platform: d0
server_id: "01 00 01 08 00 FF"
obis_code: "1-0:1.8.0*255"
unit_of_measurement: kWh
accuracy_decimals: 2
device_class: energy
state_class: total_increasing
# filters:
# - multiply: 0.0001
- platform: d0
obis_code: "1-0:2.8.0*255"
# filters:
# - multiply: 0.01
- platform: d0
obis_code: "1-0:16.7.0*255"
unit_of_measurement: W
accuracy_decimals: 1
# filters:
# - multiply: 0.1
text_sensor:
- platform: d0
obis_code: "129-129:199.130.3*255"
- platform: d0
name: "Total energy string"
