I have problems generating firmware for D1 mini and also ESP32.
I use ESPHome Current version: 2021.10.3
INFO Reading configuration /config/esphome/pir-2sensor-01.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing pir-2sensor-01 (board: az-delivery-devkit-v4; framework: arduino; platform: espressif32 @ 3.3.2)
HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash
Dependency Graph
|-- <AsyncTCP-esphome> 1.2.2
|-- <WiFi> 1.0
|-- <FS> 1.0
|-- <Update> 1.0
|-- <ESPAsyncWebServer-esphome> 2.0.0
|-- <DNSServer> 1.1.0
|-- <ESPmDNS> 1.0
Compiling /data/pir-2sensor-01/.pioenvs/pir-2sensor-01/src/esphome/components/api/api_connection.cpp.o
Compiling /data/pir-2sensor-01/.pioenvs/pir-2sensor-01/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/pir-2sensor-01/.pioenvs/pir-2sensor-01/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/pir-2sensor-01/.pioenvs/pir-2sensor-01/src/esphome/components/api/api_pb2_service.cpp.o
this is the output on my monitor.
The RasPi 3 then crashes regularly and I have to turn it off and on again.
I do not want to burn the firmware directly to the ESP32 but download it.
Sometimes it works, but this is very rare.
I have already changed the power supply and now use a 5.1V and 3A power supply.
Then I changed a microSD card and now use 64GB A2 type.
What else can I do?
Greetings Juergen
