Of course, replace all UPPERCASE with the appropriate numbers/chars for you. the colon and port can be skipped if you did not change the default (as i did). Maybe in case of error, just add it (default is 88).
Hi, I know this is an old thread, but I used your example to get my camera to show up in the ui. But, it only worked until I restarted home assistant. I’ve restarted several times since then but the camera is still not showing up. Any advice?
