Has there been any expansion for the Foscam component? I have two FI9821P that worked as ‘foscam’ and two FI8904W that I had to use ‘mjpeg’ for and am getting an enormous amount of error (as expected).
Either expand ‘foscam’ or is there a way to fix the errors?
I’ve got a Foscam FI8010E which is the wired version of the Foscam first mentioned. (Non-Wireless) I’m having the same issue. I had to run the camera as a mjpeg platform to make it work. Which this kind of stinks as the cam is very choppy this way. Vs real time.
Im trying to add a Foscam FI9828W too. Having no luck to get it to work with Home Assistant.
Tried the Foscam and the Mjpeg method and nothing works.I get this error:
17-01-25 20:08:18 requests.packages.urllib3.connectionpool: Failed to parse headers (url=http://192.168.1.7:8151/videostream.cgi?rate=0&user=xxx&pwd=xxx)
This isn’t HA as much as it is the library they are using for this. As far as I know, the issue at the library is still open.
I have a pair of 8918Ws which are essentially the same and ironically did a bunch of work on them yesterday to get curl commands working to move them to presets.
One of the things that reduced (maybe ended) these errors for me was adding the authentication type.
# Front Inside Camera
- platform: mjpeg
mjpeg_url: !secret cam1_url
authentication: digest
name: interior street facing controllable
Also, when working on my presets project, I found this which is going to help a lot of you guys out if you want to access features via curl commands!
As far as some of the other info “errors” that you get from HA on the Foscams, since they don’t affect actual operation, I’ve been filtering them with the following:
For me, some of these components generate errors that aren’t anything that affects their actual operation; for instance, I have a UHD TV with Cast built in. This is great and when it’s on, the media player shows up fine but when the TV is off I get connection errors. Since I know this is in the process of being fixed (possibly in .37), I’m just suppressing them for now. If something nasty happens, I’ll still get an error. This is a personal choice; I’m not saying you should just ignore errors in your log. But if you know what they are and if you know they are not critical, this is a way to filter them out.
Hope this helps; I didn’t see a lot of Foscam info when I first came here so I wanted to try to add to the knowledge base.
Give me a little time and I’ll put up what I did with presets; really the only difference would be looking up which command number and CGI to put in the URL. And you should be able to get that from the CGI PDF I posted.
Here’s what I came up with for the preset commands
Go to preset 1 - http://CAM_IP/decoder_control.cgi?command=31&user=USER&pwd=PASSWORD
Go to preset 2 - http://CAM_IP/decoder_control.cgi?command=33&user=USER&pwd=PASSWORD
Go to preset 3 - http://CAM_IP/decoder_control.cgi?command=35&user=USER&pwd=PASSWORD
Go to preset 4 - http://CAM_IP/decoder_control.cgi?command=37&user=USER&pwd=PASSWORD
Go to preset 5 - http://CAM_IP/decoder_control.cgi?command=39&user=USER&pwd=PASSWORD
I also have a cam that faces a window so I turn off the IR otherwise the reflection washes everything out.
Turn off IR lamp - http://CAM_IP/decoder_control.cgi?command=95&user=USER&pwd=PASSWORD
I created scripts for each one to send these commands via cURL here’s an example of one of them:
I was just doing some research into pan and tilt indoor cameras that work with HA and it looks like Foscam is a good option. However, there is a question as to which model to go for, as some seem problematic (as this thread highlights) and some of the older models are selling out while there are new ones that haven’t been mentioned.
But there is also the FI9816P. Has anyone got this working? The reviews aren’t encouraging on Amazon, but then neither are those for the FI9821P. I assume it doesn’t matter too much as Home Assistant will be doing all the work.
i dont know about that specific cam, but i recently bought a C1 lite for 26 euro
it has the same CGI so i can control it on the same way as the F19828P (without PTZ off course)
so the most important is to find out which type of CGI the cam uses.
You should be able to see something in a browser if you try these URLs and replace the capitalized variables with your actual info. If you do, then it should work in HA as well. At least the first one; you’ll have to set up FFMPEG to use the other one, of course.
If you can find a reference of the CGI commands like I did with the 8918w, you can create scripts and use cURL commands to move the cams, at least to the presets if nothing else. I’m doing it myself with an input select.
