Problems with home assistant and google home
I’m having trouble setting up my google home mini integration with HA.
I’ve successfully setup duckdns and ssl. I can co to https://xxxx.duckdns.com and login to home assistant.
In home assistant config I have logged into home assistant cloud.
Cloud connection status - Connected
I scroll down to - * [Activate the Home Assistant skill for Google Assistant]
I’ve linked accounts
when I click send to google home, my home mini says “sorry I could not find that”
If i send to android device, nothing happens on my phone
on the google home app, I can add hass.io, type in my email and password, allow access, then I get the error “could not update the setting. check your connection”
what am I missing?
I have exactly the same problem. Did you find a solution?
I have the same problem. Can someone help us?
I had this problem but eventually got it working, and I don’t remember exactly how … but I think the hass skill page on assistant.google.com still had the word “link” next to “send to device” before it was working - whereas now that it is working it says “unlink”. Is that the case for you?
Have you considered installing the component instead?
It’s more straight forward than it first looks.
